SC16IS752 UART I2C Routines Library
Post new topic   Reply to topic    CCS Forum Index -> Code Library
dyeatman
PostPosted: Sun Oct 26, 2008 8:35 pm     Reply with quote
// SC16IS752 UART Routines Library
// Filename     : SC16IS752 UART I2C Routines.c
// Programmer   : Dave Yeatman
// Version      : 10/27/2008
// Remarks      : This example provides framework code to communicate with
//                the NXP SC16IS752 Dual Channel UART using I2C. This UART driver
//                has been tested for both UART Channel 0 (A) and Channel 1 (B).
//                The GPIO I/O functions have also been tested.
//                More information on the UART can be found at www.NXP.com:
// SC16IS752 Dual UART Register Defines
#define RHR          0x00 //  Recv Holding Register is 0x00 in READ Mode
#define THR          0x00 //  Xmit Holding Register is 0x00 in WRITE Mode
#define IER          0x01  // Interrupt Enable Register
#define IIR          0x02  // Interrupt Identification Register in READ Mode
#define FCR          0x02  // FIFO Control Register in WRITE Mode
#define LCR          0x03  // Line Control Register
#define MCR          0x04  // Modem Control Register
#define LSR          0x05  // Line status Register
#define MSR          0x06  // Modem Status Register
#Define SPR          0x07  // ScratchPad Register
#define TCR          0x06  // Transmission Control Register
#define TLR          0x07  // Trigger Level Register
#define TXLVL        0x08  // Xmit FIFO Level Register
#define RXLVL        0x09  // Recv FIFO Level Register
#define IODir        0x0A  // I/O P:ins Direction Register
#define IOState      0x0B  // I/O Pins State Register
#define IOIntEna     0x0C  // I/O Interrupt Enable Register
#define IOControl    0x0E  // I/O Pins Control Register
#define EFCR         0x0F  // Extra Features Control Register
#define DLL          0x00  // Divisor Latch LSB  0x00
#define DLH          0x01  // Divisor Latch MSB  0x01
#define EFR          0x02  // Enhanced Function Register
#define I2CWRITE     0x00
#define I2CREAD      0x01
#define CHANA      0
#define CHANB      1
byte ReadUART(int8 RegAddr, int1 CHAN)   // Internal register address plus channel #(0 or 1)
   { // returns byte read from the UART register
   byte  data;
   I2C_Start();
   Delay_us(15);
   I2C_write(UART_ADDR);  // write cycle
   I2C_write((RegAddr << 3) | (CHAN << 1)); // write cycle for reg address to selected channel
   I2C_Start(); // restart
   Delay_us(15);
   I2C_write(UART_ADDR | I2CREAD);  // read cycle
   data=I2C_read(0);
   I2C_Stop();
   return(data);
void WriteUART(int8 RegAddr, int1 CHAN, byte Data) // Internal register address plus channel #(0 or 1)
   { // sends data byte to selected UART register
   I2C_Start();
   Delay_us(15);
   I2C_write(data);
   I2C_Stop();
void UART_Send_Char(int1 CHAN, byte Data) //channel #(0 or 1) plus the data byte to be sent
{ // send byte to UART Xmit via the I2C bus
     WriteUART(THR, CHAN, Data);  // send data to UART Transmit Holding Register
void Init_SC16IS752 (void)
  // This init routine initializes ChannelS A and B
  // Channel A Setups
  //Prescaler in MCR defaults on MCU reset to the value of 1
  WriteUART(LCR, CHANA, 0x80); // 0x80 to program baud rate divisor
  WriteUART(DLL, CHANA, 0x18); // 0x18=9600K, 0x06 =38,42K with X1=3.6864MHz
  WriteUART(DLH, CHANA, 0x00); //
  WriteUART(LCR, CHANA, 0xBF); // access EFR register
  WriteUART(EFR, CHANA, 0X10); // enable enhanced registers
  WriteUART(LCR, CHANA, 0x03); // 8 data bits, 1 stop bit, no parity
  WriteUART(FCR, CHANA, 0x07); // reset TXFIFO, reset RXFIFO, enable FIFO mode
  // Channel B Setups
  WriteUART(LCR, CHANB, 0x80); // 0x80 to program baud rate divisor
  WriteUART(DLL, CHANB, 0x18); // 0x18=9600K, 0x06 =38,42K with X1=3.6864MHz
  WriteUART(DLH, CHANB, 0x00); //
  WriteUART(LCR, CHANB, 0xBF); // access EFR register
  WriteUART(EFR, CHANB, 0X10); // enable enhanced registers
  WriteUART(LCR, CHANB, 0x03); // 8 data bits, 1 stop bit, no parity
  WriteUART(FCR, CHANB, 0x07); // reset TXFIFO, reset RXFIFO, enable FIFO mode
char Poll_UART_RHR(CHAN)
   { // Poll UART to determine if data is waiting
     char data = 0x00;
     if (ReadUART(LSR, CHAN) & 0x01) // is data waiting??
        { // data present in receiver FIFO
             data = ReadUART(RHR, CHAN);
// return received char or zero
     return(data);
void Set_GPIO_Dir(bits)
   { // Set Direction on UART GPIO Port pins GPIO0 to GPIO7
     // 0=input   1=Output
     WriteUART(IOControl, 0, 0x03); // Set the IOControl Register to GPIO Control
     WriteUART(IODir,0, bits); // output the control bits to the IO Direction Register
byte Read_GPIO()
   { // Read UART GPIO Port
     char data = 0x00;
     data=ReadUART(IOState,0); // get GPIO Bits state 0-7
// return data bits state or zero
     return(data);
void Write_GPIO(data)
   { // Load UART GPIO Port
     WriteUART(IOState,0, data); // set GPIO Output pins state 0-7
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
