About RTOS!
Thuan
About RTOS!
PostPosted: Fri Oct 24, 2008 9:00 pm     Reply with quote
Hi everybody!
I know that RTOS in CCS doesn't support the piority of tasks. So if I have 2 or more task which can be appear in the same time, so what will happen?
For example : 100ms is period of task 1. 250ms is period of task 2. At t=500ms we see that both of task are allowed to run. How does CCS decide which tasks is allowed to run first.
Could you give a advice?
Thanks a lot!
PostPosted: Sat Oct 25, 2008 4:06 am     Reply with quote
If it is like the rest of the CCS code, my guess would be that it tests the tasks, in the order they are defined in the code. It then services the first one it finds needing service.
