PIC16F877A and a 4X4 Keypad
Legatus
PostPosted: Thu Oct 23, 2008 4:24 am     Reply with quote
A relatively simple question for you guys.
How can I integrate a 4x4 keypad with a pic16f877a microcontroller using ccs?
Smile
Kabukiman
PostPosted: Thu Oct 23, 2008 6:18 am     Reply with quote
You can adjust the default driver kbd.c to your keypad 4x4 or
write your own function to read keypad.
PostPosted: Thu Oct 23, 2008 11:57 am     Reply with quote
Use the forum's search page:
http://www.ccsinfo.com/forum/search.php
Search for:
4x4 keypad
You will find posts like this:
http://www.ccsinfo.com/forum/viewtopic.php?t=32297
Belial
PostPosted: Thu Oct 23, 2008 1:03 pm     Reply with quote
I make a function to read a keypad 4x4 myself, all keys are connected to
PORTC you can connect at any PORT with 8 pins
I don't know it's very efficient but works good luck.
 SET_TRIS_C(0b11110000);//you mus set in main function before infinite loop port configuration
void main{
  while(1){
      key = readkey(); // Call the function
      if(key!='\0')     // if key different '\0' show it else do nothing
          if(x > 16 && y == 1){
          x=0;
          y=2;
          }else if(x>16 && y==2)
           printf(lcd_putc,"\f");
           x=0;y=1;
          x++;
          lcd_gotoxy(x,y);
          printf(lcd_putc,"%c",key);
          delay_ms(300);
char readkey()
     output_low(PIN_C1);
     output_low(PIN_C2);
     output_low(PIN_C3);
     output_high(PIN_C0);
     if(input_state(PIN_C4)==1)
         return '1';
     if(input_state(PIN_C5)==1)
         return '4';
     if(input_state(PIN_C6)==1)
         return '7';
     if(input_state(PIN_C7)==1)
         return '*';
     output_low(PIN_C0);
     output_low(PIN_C0);
     output_low(PIN_C2);
     output_low(PIN_C3);
     output_high(PIN_C1);
         return '2';
         return '5';
         return '8';
         return '0';
     output_low(PIN_C1);
     output_low(PIN_C0);
     output_low(PIN_C1);
     output_low(PIN_C3);
     output_high(PIN_C2);
         return '3';
         return '6';
         return '9';
         return '#';
     output_low(PIN_C2);
     output_low(PIN_C0);
     output_low(PIN_C1);
     output_low(PIN_C2);
     output_high(PIN_C3);
         return 'A';
         return 'B';
         return 'C';
         return 'D';
     output_low(PIN_C3);
      return '\0';
Legatus
PostPosted: Thu Oct 23, 2008 7:59 pm     Reply with quote
Search for:
4x4 keypad
Sorry, I should've searched the forums before posting.
Legatus
PostPosted: Thu Oct 23, 2008 8:02 pm     Reply with quote
x=0;
y=2;
x=0;y=1;
x++;
lcd_gotoxy(x,y);
delay_ms(300);
Please do correct me if i'm mistaken, these are for printing the pressed key to the lcd.
PostPosted: Fri Oct 24, 2008 8:19 am     Reply with quote
Yes this is for print to lcd
Legatus
PostPosted: Wed Oct 29, 2008 3:40 am     Reply with quote
I make a function to read a keypad 4x4 myself, all keys are connected to PORTC you can connect at any PORT with 8 pins
How would I know which keypad pin is connected to which port pin?
Thanks.
Smile
kabukiman85
Keypad
PostPosted: Thu Oct 30, 2008 5:30 am     Reply with quote
You can connect your keypad to any port with 8 pins in my example, I use 8 pins on PORTC.
This is my own made keypad 4x4 with mikroe schematics
Razz
I'm using it on EasyPic5 mikroe dev Board
Here are the schematics of this keypad
http://www.mikroe.com/pdf/keypad_board_schematic.pdf
Laughing
John P
PostPosted: Thu Oct 30, 2008 8:19 am     Reply with quote
In fact the schematic shows PORTB, and I think it's right. If you use PORTB, you have internal pullups available, so you can be sure the state of any input is high, unless it's pulled down by one of the outputs. Anyway, on a lot of the processors, PORTC has all the communication pins. You wouldn't want to tie up the whole port with the keypad.
