Salenko
about EX_STISR.C |
Posted: Thu Oct 23, 2008 3:39 am |
Everybody hi,
I will really appreciate that anyone explain me what is happening in the TBE interruption routine (next_in, next_out roles etc... ) and how bgetc() functions ??, I tryed to understand them but without success.
#int_tbe
void serial_isr() {
if(t_next_in!=t_next_out)
putc(t_buffer[t_next_out]);
t_next_out=(t_next_out+1) % T_BUFFER_SIZE;
disable_interrupts(int_tbe);
void bputc(char c) {
short restart;
int ni;
restart=t_next_in==t_next_out;
t_buffer[t_next_in]=c;
ni=(t_next_in+1) % T_BUFFER_SIZE;
while(ni==t_next_out);
t_next_in=ni;
if(restart)
enable_interrupts(int_tbe);
thanks in advance and excuse me . |
Posted: Thu Oct 23, 2008 2:35 pm |
It's an interrupt-controlled circular buffer for the UART transmitter. It allows you to put up to 64 characters in the buffer and they will be transmitted automatically. Normally, to transmit several characters, your code has to wait until each character is sent, before the program can move on to the next section of code. In other words, the putc() function
"blocks" program flow. It can take over 60 ms to transmit 64 characters
if you just use printf() to send them. The interrupt-controlled circular
transmit buffer solves this problem. |
newguy
Posted: Thu Oct 23, 2008 3:03 pm |
As PCM has pointed out, using interrupts gets around the blocking issue, which is a fancy way of saying that it avoids occupying the processor 100% until the entire message has been sent.
The TBE interrupt stands for Transmit Buffer Empty. In your startup code at the top of main(), never enable the TBE interrupt. If you're not sending data out via the USART, the transmit buffer will always be empty and the TBE interrupt will always "fire". For this reason, the bputc() function has the check to see if the character being sent is the first one - if it is, then the TBE interrupt is enabled because you want to know when it's safe to send the next character of your message. bputc() also has another check to see if you've completely filled your transmit buffer - if it is full, the code just waits in the while loop for the TBE routine to transmit another character.
The TBE routine just sends the current character and increments the "pointer" that will let it know which character has to be sent next time around. It also performs a check to see if there are any unsent characters left in the buffer (filled by bputc()), and if there aren't, it disables any further TBE interrupts.
Clear? |
Salenko
Posted: Thu Oct 23, 2008 5:13 pm |
PCM programmer wrote: | It's an interrupt-controlled circular buffer for the UART transmitter. It allows you to put up to 64 characters in the buffer and they will be transmitted automatically. Normally, to transmit several characters, your code has to wait until each character is sent, before the program can move on to the next section of code. In other words, the putc() function "blocks" program flow. It can take over 60 ms to transmit 64 characters if you just use printf() to send them. The interrupt-controlled circulartransmit buffer solves this problem. |
hi,
Thank you PCM Programmer for taking time to answer me, now the advantage of the interrupt-controlled circular buffer is clear to me.
Salenko
Posted: Thu Oct 23, 2008 5:26 pm |
newguy wrote: | As PCM has pointed out, using interrupts gets around the blocking issue, which is a fancy way of saying that it avoids occupying the processor 100% until the entire message has been sent.
Clear? |
Hi newguy,
thank you too for taking time to explain the routines to me, I can say that I understood the essential of both of them. I think that basically, I was confused because of the name of the routine TBE (Transmit Buffer Empty) which led me to assume that this interruption is only enabled when the buffer is empty (totally empty).
Just to verify my understanding: in the other side (I mean the receiver microcontroller), the RDA routine and bgetc() (associated with bkhit()) are doing basically the same work but in reception as the TBE and bputc() in trasmission. is it right ? |
newguy
Posted: Thu Oct 23, 2008 8:19 pm |
Right. RDA = Receive Data Available. It only "fires" when the USART receives a valid character. The CCS example (I think it's called EX_SISR.c) simply retrieves the last character and places it in the receive buffer. |
Salenko
Posted: Fri Oct 24, 2008 7:45 am |
newguy wrote: | Right. RDA = Receive Data Available. It only "fires" when the USART receives a valid character. The CCS example (I think it's called EX_SISR.c) simply retrieves the last character and places it in the receive buffer. |
Hi newguy,
right, it is called EX_SISR.C
thank you for your explanations. ![Wink](images/smiles/icon_wink.gif) |
