12bit transmit over RS232
pvol
PostPosted: Sun Oct 19, 2008 3:42 am     Reply with quote
hello...
i need to transmit 12bit value over 232
how can i do this?
232 has 8bit data
one thought is to split 12bit in 2 bytes and transfer it separately.
but its very difficulty to join them at the pc (i use labview )
is there a simple way to do this?
thank you..
PostPosted: Sun Oct 19, 2008 3:56 am     Reply with quote
That's exclusively a LabView problem to my opinion. But why not sending the data decimal or hex coded?
pvol
PostPosted: Sun Oct 19, 2008 4:09 am     Reply with quote
can i send a number >255 ?
let's say, as example that
i write printf("500\n");
what value will send to pc?
PostPosted: Sun Oct 19, 2008 4:22 am     Reply with quote
Printf, as you show there, sends _text_. Nothing whatsovever to stop you sending (for instance) '25000', but over the RS232, this will be sent as five ASCII text characters, not '12 bits'. This is probably the easiest way to do what you want, but will take more time over the RS232.
pvol
PostPosted: Sun Oct 19, 2008 4:35 am     Reply with quote
in order to send '25000' what must i do so that the computer understands 25000 as a number and not as characters?
what kind of transformation must i do at the CCS?
PostPosted: Sun Oct 19, 2008 4:37 am     Reply with quote
You should use %lu respectively %ld printf format with CCS C to display int16 values.
pvol
PostPosted: Sun Oct 19, 2008 4:50 am     Reply with quote
i'll try it and i'll tell you the results
thanks for the answers...
pvol
PostPosted: Wed Oct 22, 2008 12:54 am     Reply with quote
i tried this and works fine!!
now i have another problem
i want to present an array that has got negative numbers on labview
int array[6]={10 20 30 -10 -20 -30}
for (i=1;i<=6,i++)
{printf("u% \n"array[i])}
10 20 30 plotted
but -10 -20 -30 not!
what is your opinion about this?
is it possible to sent (and present) negative numbers?
Salenko
PostPosted: Wed Oct 22, 2008 1:09 am     Reply with quote
for (i=1;i<=6,i++)
10 20 30 plotted
I think you should use signed int format: %d
pvol
PostPosted: Thu Oct 23, 2008 2:57 am     Reply with quote
thank you!!!
works great!! Very Happy Very Happy
