ascii char to decimal conversion
PostPosted: Wed Oct 22, 2008 8:43 am     Reply with quote
This may be a dumb question, but i cant seem to find the solution. I have commands coming in from rs232 and i need to convert the ascii values to decimal values.
"Command01" converted and assigned to
int8 command = 1;
or more simply:
"255" converted and assigned to
int8 command = 255;
I dont see any built in function and dont see how sprintf or printf can help???
PostPosted: Wed Oct 22, 2008 8:49 am     Reply with quote
It's called - atoi() for ASCII to int - this is part of the standard C library and is in every C compiler I have ever seen.
HTH - Steve H
rnielsen
PostPosted: Wed Oct 22, 2008 8:51 am     Reply with quote
Look up atoi().
Embarassed
thought there was a simple solution
