dspic30 Bootloader Question
PostPosted: Fri Oct 17, 2008 9:40 am     Reply with quote
Has anyone used the ingenia bootloader? So far it's the only bootloader I've been able to get to the point of loading a program on a dspic30. I realize this isn't ingenia's site, but they don't have a ton of documentation.
My question is this:
I get a warning that my hex file contains data in protected 'config' addresses, protected addresses will not be overwritten.
Even with a very simple blinking program, I get this error
#include <30F4011.h>
#device *=16
#FUSES NOWDT,XT_PLL16,NOCKSFSM,PUT64,NOBROWNOUT,NOPWMPIN,NOPROTECT,NOWRT,NODEBUG,NOCOE,ICS0,RESERVED
#use delay(clock=117964800)
     output_toggle(PIN_B0);  //hooked up to an LED
what lines of this code would the CCS compiler place in configuration memory
asmallri
PostPosted: Fri Oct 17, 2008 10:52 am     Reply with quote
Everything in the #fuse directive is placed in protect memory.
Fuses configure the PIC for your target hardware platform. This is the same information that is required for a bootloader. As the bootloader is the first thing installed on the PIC, the bootloader's fuse setting will be inherited by the application program bootloaded to the PIC.
A bootloader usually silently discards the config records (fuses settings). In your case the bootloader issues a warning message. My suggestion is do NOT make any changes to the application program and simply ignore the bootloader warning message. If possible, modify the bootloader to prevent it from issuing this class of warning message.
Regards, Andrew
PostPosted: Fri Oct 17, 2008 11:30 am     Reply with quote
Even when I comment out the #fuse statements, there are still values in the F80000 adresses.
asmallri
PostPosted: Fri Oct 17, 2008 11:54 am     Reply with quote
The hex file will still contain values at F80000 even if they are all 0xFF
The problem is the bootloader not the application.
Regards, Andrew
