newbee Guest
18F4620 as a hyperterminal |
Posted: Fri Oct 17, 2008 9:49 am |
I am very new to micro controllers, and was wondering if this forum can help. I am trying to make a 18F4620 work in both echo mode and respnsive mode, by that I mean, when i type ':' on the hyperterminal I should get an ':' back also I should get the value attached with ':'
Example :
Hyperterminal Input:
Hyperterminal output:
::a
I have followed the codes suggested in the links in this website, and formulated my code..and this is as follows ..
void ui_handle(void)
char c;
c=fgetc(USER);
fputc(c,USER);
c=toupper(c);
switch(c) {
case ':' : delay_ms(3000);
fputc('a',USER);
////The main Program is as follows
void main() //was previously "void main(void)", Tirtho
enable_interrupts(INT_RDA); //Tirtho
enable_interrupts(GLOBAL); //Tirtho
while (TRUE)
////////the interrupt program
#int_rda
void rda_isr(void)
ui_handle();
Looking forward to hearing from you guys..
Cheers
Dave |
Posted: Fri Oct 17, 2008 10:43 am |
What, if any, response do you get when you run your code?
Is this a copied and pasted version of your code? I see a few syntax errors that would cause the code to not even compile. You also don't have a #use rs232 statement, so your baud rate is undefined.
Even though it won't give you a compiler error, it is bad practice to use delays in interrupt service routines. If you type two characters within 3 seconds of each other, the second one will be missed, since you are stuck in a 3 second delay. Look at ex_sisr.c in the example folder. Use this int_rda, and bgetc(). don't forget to define bkbhit. Then, in your while(1) loop in the main function, poll bkbhit. If its true, call bgetc. Then do your switch case/delays/echoing. This way, you won't miss received characters.
Also, what program are you using as a terminal? I've had problems using hyperterminal to send characters. I prefer realterm. Everything is configurable, and half duplex is possible. |
Newbee Guest
Posted: Fri Oct 17, 2008 10:53 am |
Well yes I have not pasted the whole code. The code compiles and the present output is something like this
hyperterminal output:
:a
So its not echoing back ':' when it is typed, so thats where the problem arisis. If I concetrate on the echo mode, then the charecter does not get displayed, so its like vice-versa. But I want them both to work together, which is the ultimate solution.
Dave |
Posted: Fri Oct 17, 2008 11:03 am |
Maybe I'm not understanding the problem.
Do you want hyperterminal to echo the original ':' or the PIC? |
Newbee Guest
Posted: Fri Oct 17, 2008 11:08 am |
The PIC, I want the PIC to echo characters sent to it, and respond to the characters which the input is associated with. |
Posted: Fri Oct 17, 2008 11:25 am |
Currently, your code is set up to only print one ':', when it echos. So the code is echoing the input ':', but you haven't told it to send the second ':'.
place fputc(':',USER) inside the case ':' construct, above fputc('a',USER) |
