Code generates errors!
rougie
PostPosted: Sun Oct 12, 2008 7:55 pm     Reply with quote
Can someone tell me why the following code fragment generates errors?
Basically I am passing a pointer of struct type by reference to a function!
#include <Dv4685.h>
#include <stdlib.h>
#include <stdlibm.h>
#include <MATH.H>
enum enum_OBJTASK {e_CREATE=1, e_MODIFY, e_FREE};
typedef struct passCode {
int TOUCHES;
int LEAST_X;
int FAR_X;
int LEAST_Y;
int FAR_Y;
int DISP_INTRVL;
int MSG_NUM;
} PASSCODE;
void ULC_PASSC_config_passcode (enum_OBJTASK OBJ_CNTRL,
PASSCODE **obj_PASSCODE,
int TOUCHES,
int ID_LEAST_X,
int ID_FAR_X,
int ID_LEAST_Y,
int ID_FAR_Y,
int DISP_INTERVAL,
int MSG_NUM)
switch (OBJ_CNTRL)
case e_CREATE:
*obj_PASSCODE = (PASSCODE*) malloc (sizeof (PASSCODE));
case e_MODIFY:
(*obj_PASSCODE)->TOUCHES = TOUCHES;
(*obj_PASSCODE)->LEAST_X = ID_LEAST_X;
(*obj_PASSCODE)->FAR_X = ID_FAR_X;
(*obj_PASSCODE)->LEAST_Y = ID_LEAST_Y;
(*obj_PASSCODE)->FAR_Y = ID_FAR_Y;
(*obj_PASSCODE)->DISP_INTRVL = DISP_INTERVAL;
(*obj_PASSCODE)->MSG_NUM = MSG_NUM;
case e_FREE:
free(*obj_PASSCODE);
*obj_PASSCODE = NULL;
PASSCODE *obj_PASSCODE; // CREATE A passCode POINTER
ULC_PASSC_config_passcode(e_CREATE, &obj_PASSCODE, 4,0,0,0,0,0,0);
ULC_PASSC_config_passcode(e_FREE, &obj_PASSCODE, 0,0,0,0,0,0,0);
If you just copy the above code and compile you can see how errors will occur.
All help appreciated!
Best regards
Robert
FvM
PostPosted: Mon Oct 13, 2008 12:00 am     Reply with quote
please also tell the compiler type and version.
However, I also experienced problems of CCS C to understand double indirection, thus I had to recode some functions used since years with various C compilers. The below version, with should be equivalent to your code, is accepted by PCD V4.079, but I didn't check for correct operation.
int TOUCHES;
int LEAST_X;
int FAR_X;
int LEAST_Y;
int FAR_Y;
int DISP_INTRVL;
int MSG_NUM;
} PASSCODE, *PPASSCODE;
PPASSCODE *obj_PASSCODE,
int TOUCHES,
int ID_LEAST_X,
int ID_FAR_X,
int ID_LEAST_Y,
int ID_FAR_Y,
int DISP_INTERVAL,
int MSG_NUM)
PPASSCODE opc;
switch (OBJ_CNTRL)
case e_CREATE:
*obj_PASSCODE = (PPASSCODE) malloc (sizeof (PASSCODE));
opc = *obj_PASSCODE;
case e_MODIFY:
opc->TOUCHES = TOUCHES;
opc->LEAST_X = ID_LEAST_X;
opc->FAR_X = ID_FAR_X;
opc->LEAST_Y = ID_LEAST_Y;
opc->FAR_Y = ID_FAR_Y;
opc->DISP_INTRVL = DISP_INTERVAL;
opc->MSG_NUM = MSG_NUM;
case e_FREE:
PPASSCODE obj_PASSCODE; // CREATE A passCode POINTER
Regards,
Frank
Hello FvM
PostPosted: Tue Oct 14, 2008 2:41 pm     Reply with quote
Thanks for your post,
I will try to see if CCS comes up with a fix. I was really hoping to use multiple indirection (**).
Or else, I will use your way, which I am sure it works.
I don't understand why CCS compiler has these issues?
Anyways, I thank you very much for your post, much appreciated!
Regards
Roberto
