wanna know about delay in ADC
hayee
PostPosted: Thu Oct 09, 2008 11:30 pm     Reply with quote
I am working on 18f452.I have some Analoge Channels Some digital Inputs.Exactly i want to know that is it necessary to add a delay in adc routine for example
set_adc_channel(2);
  delay_ms(5);
  ts1=read_adc();
  ts2=(ts1*0.488);//ts2=((ts1*5)/1023)*100 => ts2=(ts1*0.488)
  rotate_left(&ts2,2);
  hold_regs[10]=ts2;//loading value of ts2 in holding register
Here the delay is too much because i want to run the entire program in 55uS.My program consists of 4 analoge channels so it would be take too much time.
i used another technique.i have initialize a counter.when a conter reaches at a particular value it read adc like
set_adc_channel(2);
if(counter==2400)
  ts1=read_adc();
But by doing this when i vary any one analoge channel by potentiometer all analoge channels varies.
Tell me another way for doing this
Rohit de Sa
PostPosted: Fri Oct 10, 2008 12:29 am     Reply with quote
The datasheet states:
The A/D conversion time per bit is defined as TAD. A minimum wait of 2 TAD is required before the next acquisition starts......The A/D conversion requires 12 TAD per 10-bit conversion.
This comes up to be a little under 12us for temperatures around 25 degC.
When changing ADC channels it is recommended that you wait about 20us before doing an ADC read to allow for ADC settling. You do not need to wait for 5ms.
I don't see you changing channels.
I have no idea what you are trying to do here.
I don't think its possible to read 4 channels in 55us using the '452. You may want to try a higher end PIC or switch to an external ADC.
Rohit
