casting to a int1
Will Reeve
casting to a int1
PostPosted: Fri Jun 06, 2003 3:27 am     Reply with quote
I was just wondering:
int1 fred;
int16 b;
b = 0x80;
fred = (int1)(b);
is fred == 1 after this line.
Will
P.S. Away from my hardware at the moment so can't check myself!
___________________________
Original Post ID: 144515058
R.J.Hamlett
Re: casting to a int1
PostPosted: Fri Jun 06, 2003 3:55 am     Reply with quote
:=I was just wondering:
:=int1 fred;
:=int16 b;
:=b = 0x80;
:=fred = (int1)(b);
:=is fred == 1 after this line.
:=Will
:=P.S. Away from my hardware at the moment so can't check myself!
Yes.
This is one cast, that the CCS compiler does quite nicely. Generally, it does an 'or' on the larger value, and sets/resets the target bit according to whether this is zero or not.
Original Post ID: 144515059
Will Reeve
PostPosted: Fri Jun 06, 2003 9:22 am     Reply with quote
Thanks, just the answer I was hopeing for!
Cheers,
Will
Original Post ID: 144515070
kender
Does it still work that way?
PostPosted: Wed Oct 08, 2008 12:44 pm     Reply with quote
Hm, I wonder if the ‘OR’ still works in the newer versions of the compiler?
I've got different values of bLoop after
 bLoop = (int1)(input_PCA9536() & APPLICATOR_DETECT);  // always zer0
and
bLoop = ((input_PCA9536() & APPLICATOR_DETECT) > 0);
were different (all inputs being equal). APPLICATOR_DETECT = 0x02 and input_PCA9536() returns a byte.
PCWH 4.071, PIC18LF4525
Read the label, before opening a can of worms.
FvM
PostPosted: Wed Oct 08, 2008 1:20 pm     Reply with quote
If you regard int1 as a boolean type according to the C standard (the only plausible understanding, I think) than the below rule from C standard applies:
When any scalar value is converted to _Bool, the result is 0 if the value compares equal to 0; otherwise, the result is 1.
However, CCS C V3 as well as V4 have some problems with type casts to boolean, e. g. when using integer values with logical operators. An expression as (val1 && val2) clearly requires a type conversion of each operand to boolean followed by a logical and. But this doesn't always work with CCS.
PostPosted: Wed Oct 08, 2008 1:40 pm     Reply with quote
Your posted code shows bitwise 'AND' operations, not 'OR'.
Also, post the value returned by input_PCA9536().
PostPosted: Wed Oct 08, 2008 2:47 pm     Reply with quote
It is worth reading the documentation that comes with the compiler.
Readme.txt, for the current versions. Tail end, you have the statement:
"Mode CCS2:
onebit = eightbits is compiled as onebit = (eightbits != 0)
all other modes compile as: onebit = (eightbits & 1)"
This is the operation performed by the cast.
This was changed as part of the changes to be ANSI compliant.
The old logical test on the whole byte, was implicit in the original C paperwork (as already stated here), but ANSI C, specifies the conversion to only test the least significant bit. It does seem a 'retrograde' step (the old form was quite useful, and logical), but this is why the behaviour has changed.
FvM
PostPosted: Wed Oct 08, 2008 5:23 pm     Reply with quote
Thank you for pointing to the compilation modes. I didn't yet find a ANSI C specification, that explicitely requires the treatment of the type conversion to int1 as done since CCS V3, but I see, that it can be regarded as a consistent result of giving up the C99 boolean type and the respective special arrangements.
I also have to correct my above statement in so far, that the (val1 && val2) expression is treated correct by CCS C normally. The operands are not casted to int1, the expression is treated equivalent to ((val1 != 0) && (val2 != 0)) as it should be. There is a problem with logical expressions involving bit fields, but it isn't related to the present discussion, as far as I see.
