I try this x = (int) lat /100
to make x = 25 ;
but it not work
help please
Posted: Wed Oct 08, 2008 12:26 pm
In CCS, an 'int' is the same size as 'unsigned char' in C18.
To translate C18 code to CCS, you need to change every instance
of 'int' to 'signed int16'.
libor
Posted: Wed Oct 08, 2008 1:14 pm
Btw. Has someone ever collected the comprehensive set of rules (like replace every 'xxx' with 'yyy', etc.) of converting C18 code to CCS ?
If yes, could it be automated as easily as writing some macros into a text editor ?
