CompactFlash to UART Interface
cfernandez
PostPosted: Tue Oct 07, 2008 11:55 am     Reply with quote
I need to make a CompactFlash product for windows CE & Mobile, Plug & Play COM Port. For this I search for some chip to make this interface with my PIC by UART.
Somebody know how to make this or which chip I can use?
thank you very much!!
EdWaugh
PostPosted: Wed Oct 08, 2008 4:13 am     Reply with quote
I don't think such a device exists as far as I know. You would need to interface to the compact flash parallel interface directly using a PIC with loads of pins, you could then write a fairly complex piece of software to do the translation. MMC/SD is easier to interface than compactflash, you could try that...
ed
cfernandez
PostPosted: Wed Oct 08, 2008 10:04 am     Reply with quote
The point is that we need that windows Mobile detect a COM port when I insert this hardware. I see the chip VPU16550 from Elan, but I want to know if exists other or if somebody develop a similar project.
Thank you very much!
Best Regards,
