baud rate out of range
Hampton
PostPosted: Mon Oct 06, 2008 10:35 am     Reply with quote
I'm using a PIC24FJ64GA004 and using an 8 MHz xtal with 4x PLL to get 32 MHz clock speed. Trying to run a uart at 115.2 kbps. When I compile I get the error "baud rate out of range".
#use rs232(UART1,baud=115200,parity=N,bits=8)
If I change the baud rate to 114600 it compiles with no error. Alternatively, if I keep the baud rate at 115200 but change the clock speed to 33 MHz (or anything higher) it compiles with no errors.
Here is my .h file
#include <24FJ64GA004.h>
#FUSES NOJTAG                   //JTAG disabled
#FUSES ICS3                     //ICD communication channel 3
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PR_PLL                   //Primary Oscillator with PLL
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is general purpose output
#FUSES NOPR                     //Pimary oscillaotr disabled
#FUSES I2C1SELD
#use delay(clock=32000000)
Running PCD 4.079. A colleague tried it in 4.080 and got the same error. Am I doing something wrong here? The PIC running at 32 MHz should be able to handle 115.2 kbps right?
PostPosted: Mon Oct 06, 2008 12:06 pm     Reply with quote
edited - information irrelevant
Hampton
PostPosted: Mon Oct 06, 2008 12:39 pm     Reply with quote
I got a response back from CCS and they say it's a compiler issue that will be addressed in the next release.
ELCouz
PostPosted: Fri Feb 20, 2015 6:22 pm     Reply with quote
Wow I ran into the same problem but with the V5.042 ...
CCS didn't fix it or broke it again?
#include <24FJ128GA010.h>
#FUSES XT,PR_PLL,NOPROTECT,NOJTAG,NOWDT,NOCKSFSM
#use delay(clock=32M)
#use rs232(baud=115200,UART1,ERRORS)
*** Error 96 "main.c" Line 4(5,37): Baud rate out of range
*** Error 132 "main.c" Line 45(28,29): STDOUT not defined (may be missing #USE RS232)  ::
*** Error 132 "main.c" Line 65(74,75): STDOUT not defined (may be missing #USE RS232)  ::
      3 Errors,  0 Warnings.
Build Failed.
Should I contact CCS??
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
PostPosted: Sat Feb 21, 2015 2:02 am     Reply with quote
Not the same problem (just looks it!). Smile
In your case, the UART by default uses a baud clock that is 16* the selected rate. This then leads to needing a clock at 1.8432MHz to use 115200baud. The divisions don't allow a clock close enough to this to be generated from 32Mhz, so you get this error.
You need to add the option BRGH1OK to the #use, which allows the BRGH bit to be set to '1', which then allows this to be used, and 4* the baud rate for the baud clock. 460800Hz then needed, which the compiler can get close enough to.
ELCouz
PostPosted: Sat Feb 21, 2015 8:17 am     Reply with quote
Thanks I completely forget the BRGH1OK.... I thought it was only applicable on older chips having errata / problems with the serial module.
Thanks again!
Regards,
Laurent
PostPosted: Sat Feb 21, 2015 1:03 pm     Reply with quote
Yes, it's one of those very badly documented things.
Because of the chips with faults, CCS defaults to leaving this 'off', even on chip families that don't have the fault. It really ought to default to 'on', and be selectable to off only on chips with problems.
It's particularly a problem on these later chips with the high division ratio when it's off....
ELCouz
PostPosted: Sat Feb 21, 2015 10:01 pm     Reply with quote
Thanks Ttelmah!!!!
Smile
Regards,
Laurent
Shishido
Sorry for jump in
PostPosted: Tue Apr 28, 2015 7:47 am     Reply with quote
Hello, I succeeded compile as below.
#PIN_SELECT         U1TX = PIN_B5       // UART1 transmit
#PIN_SELECT         U1RX = PIN_B6      // UART1 receive
#use rs232(baud=115200,UART1,STREAM=com_1)
main(){
int a=32;
fprintf(com_1,"test=%d ",a);
But, I am using PIC24FJ128GA010
then, I set 'FRC' to #fuse for RS232C.
Thanks Ttelmah!!!!
Smile
