12F675 Destroying Program ?
kranz
PostPosted: Thu Oct 02, 2008 7:15 am     Reply with quote
Hi.
I am having serious problems with some 12F675.
I developed a program in CCS compiler, but this program is completely destroying all my pics. I burn it in 6 working 12f675 and after I do it the pic just stop work and lose all the id's and fuses and configurations.
What is that ?
I was developing different programs to test, but it is just destroying the pics.
Here is the last example of program that just destroy the 12F675.
Obs.. I am using a JDM programmer and it is working perfect on 16F877a and 12F675 with other codes.
Program version 4.017
I already lose six 12F675. Why ?
Last test destroying program:
#include "d:\kranz\MaxC\Batevolta.h"
int qntd=0;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   //set_adc_channel(0);
   //delay_us(100);
   //qntd=read_adc();
   if(qntd < 30)
       output_high(pin_a1);
       output_low(pin_a2);
      output_low(pin_a1);
      output_high(pin_a2);
And this is the batevolta.h
#include <12F675.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                     //Master Clear pin enabled
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOBROWNOUT                 //Reset when brownout detected
SherpaDoug
PostPosted: Thu Oct 02, 2008 7:27 am     Reply with quote
Just to clarify what is happening. This code runs OK on a 16F877a and it destroys a 12F675? What do you mean by "destroy"? Does it mean the chip does not run and can no longer be programmed? You can run other code in a 12F675?
kranz
PostPosted: Thu Oct 02, 2008 7:35 am     Reply with quote
I mean, when I try to burn this code to the 12F675 it just make the 12F675 unusable.
I can't reprogram the chip anymore. Not even to reprogram a blank code.
I also can't check the Oscillator Calibrator Value anymore when I use this code.
The 16F877a example is just to say "Yes I know how to use and program pics." I was also using 12F675 processors, but with other codes, and now I don´t have any 12F675 to use because it is not working anymore to the other codes as well.
drh
PostPosted: Thu Oct 02, 2008 8:15 am     Reply with quote
From the 12F675 data sheet
Note: Erasing the device will also erase the preprogrammed
internal calibration value for
the internal oscillator. The calibration value
must be saved prior to erasing part.
Based on experience with Microchip programmers:
If your programmer doesn't save and restore the calibration value,
you won't be able to re-program the part.
David
treitmey
PostPosted: Thu Oct 02, 2008 8:17 am     Reply with quote
Did you see section 10.10 of the spec sheet.
It uses Vdd, Vss, GP0,1,3
figure 10-14
read over that section very carefully, and check wiring.
kranz
PostPosted: Thu Oct 02, 2008 8:19 am     Reply with quote
Man, the problem is..
I also CAN´T reprogram the calibrator value anymore.
I was using the winpic800, and it restores the value automatically, but after I burn this simple and useless program the pic just stop working!!!
drh
PostPosted: Thu Oct 02, 2008 8:23 am     Reply with quote
There was an older PromateII firmware version that was not handling this properly. Can you try a different programmer?
David
kranz
PostPosted: Thu Oct 02, 2008 8:30 am     Reply with quote
figure 10-14
I am using a JDM programmer.. And I already used the same programmer to burn others 12F675 codes and that is working!!!
The problem is.. I just burn and it fails and then nothing works anymore..
kranz
PostPosted: Thu Oct 02, 2008 8:39 am     Reply with quote
I also tried to use the ICprog and the same error occurs.
It just turns all the 12F675s to a completely blank processor and I can't reprogram any more.
I just have now six 12F675 blank processors with no way to restore why? Or have a way to restore this?
Obs. I am not using the code protection. Just have a look at my code.
PostPosted: Thu Oct 02, 2008 9:58 am     Reply with quote
Hi
I think you should spend some money on a real PIC programmer. In the past I had lot of problems with all kind of low cost programmers.
Microchip's pickit2 is a cheap but good programmer.
jaymiller
PostPosted: Thu Oct 02, 2008 10:01 am     Reply with quote
Before you lose ALL your hair, can you READ a previously programmed 12F675, say from a currently functioning project?
NOT one of the 'blank' ones..but one you can yank from an 'up and running' board?
This test would at least verify that your programmer + software acknowledge the 12F675 series of chips.
I know, it's mighty frustrating.....like spending a half hour staring at code only to see you didn't cut and paste the ;........arrgh.....
Jay
PostPosted: Thu Oct 02, 2008 12:10 pm     Reply with quote
#include <12F675.h>
#device adc=8
#FUSES NOWDT
#FUSES INTRC_IO
#FUSES NOCPD
#FUSES NOPROTECT
#FUSES NOMCLR
#FUSES NOPUT
#FUSES NOBROWNOUT
This problem has been discussed on the internet for years. Use Google
to find it. Here's the search string for Google.
JDM programmer 12F675
It finds this thread on the very first hit:
http://www.rcgroups.com/forums/showthread.php?t=433790
kranz
PostPosted: Fri Oct 03, 2008 11:56 am     Reply with quote
Jay
Man..
I already used this JDM programmer a lot of times.. I CAN read any other code in the working processors..
I am saying is just this code!!
kranz
PostPosted: Fri Oct 03, 2008 12:03 pm     Reply with quote
PCM programmer wrote:
#include <12F675.h>
#device adc=8
#FUSES NOWDT
#FUSES INTRC_IO
#FUSES NOCPD
#FUSES NOPROTECT
#FUSES NOMCLR
#FUSES NOPUT
#FUSES NOBROWNOUT
Thanks man..
Now I understand why.. :D
