Compile message
Aurbo
Compile message
PostPosted: Tue Sep 30, 2008 6:29 pm     Reply with quote
On compiling (v4.069), Compiler output reports
"Memory Usage: ROM=99% RAM=19%-32%"
0 Errors, 0 Warnings
Normally the code compiles at ROM=72% RAM=19%-26%
I've added a single line,
Temp16=Temp16*1.8+32; // conversion from `C to `F
and this take it to 99%
What does it mean? I've reach the limit of this particular pic and need to migrate to a larger one?
yup thats probably right
PostPosted: Tue Sep 30, 2008 9:18 pm     Reply with quote
you don't say which pic part - but i'm guessing midrange to bitty-
and that
if this is the first time you used a floating point operation in your prog - or your compiled memory tree overflowed the PIC page distribution you had -
it could be quite real and neccesary
SherpaDoug
PostPosted: Wed Oct 01, 2008 8:16 am     Reply with quote
You could try one of these:
Temp16=((Temp16*18)/10)+32; // conversion from `C to `F
Temp16=((Temp16*9)/5)+32; // conversion from `C to `F
Make sure it doesn't overflow and gives the resolution you need.
andrewg
If that is the only floating point you have in your code, then:
Temp16=Temp16*9/5+32;
avoids the use of floating point.
Andrew
rnielsen
PostPosted: Wed Oct 01, 2008 1:19 pm     Reply with quote
One thing that might be happening is the fact that the PIC's memory is organized into 'pages'. Each page can only hold so much code. If this last bit of code filled up the page that contains it then you will get that message even if you still have room in the other pages for more code.
One way of avoiding this is to avoid placing all of your code in main() and create functions to contain some of the code. This way the compiler can shift the functions around and get the most use of the PIC's memory.
Ronald
Aurbo
PostPosted: Wed Oct 01, 2008 1:50 pm     Reply with quote
Thanks everyone
The Pic in question is a 16F628A
Is working and reduced the % back down to 73%
rnielson, can you tell me a bit more about pages please.
rnielsen
PostPosted: Thu Oct 02, 2008 8:35 am     Reply with quote
Take a look at this post http://www.ccsinfo.com/forum/viewtopic.php?t=30167
Ronald
