Binary to ASCII-Lcd problem
fsven
PostPosted: Mon Sep 22, 2008 3:46 pm     Reply with quote
HI'
I'm a newbie in pic programming. Right now I'm developing a system that can convert binary input to ASCII character. Here's my coding:
#include <16f877a.h>
#use delay (clock = 40000000)
#fuses hs,noprotect,nowdt,nolvp
#BYTE PORTA=5
#BYTE PORTB=6
#BYTE PORTC=7
#include <flex_lcd.c>
#include <kbd44.c>
char n;
set_tris_a (0);
set_tris_b (0);
set_tris_c (0xff);
lcd_init();
lcd_putc("\fReady...\n");
switch( PORTC )
case 0x00000001: lcd_putc("A\n"); break;
case 0b00000011: lcd_putc("X\n"); break;
My problem is: when 2nd input trigger, the LCD overwrite onto 1st character. It cannot display after the 1st character and continuously when another input trigger. Plz help me.
TQ
PostPosted: Mon Sep 22, 2008 4:14 pm     Reply with quote
#BYTE PORTA=5
#BYTE PORTB=6
#BYTE PORTC=7
#include <kbd44.c>
char n;
set_tris_a (0);
set_tris_b (0);
set_tris_c (0xff);
This is not a real program. The 16F877A can't run faster than 20 MHz.
You have the #use delay() statement set for 40 MHz.
Also, my suggestion is to let the compiler handle the TRIS.
Use CCS i/o functions. Don't read/write directly to registers.
If you want to read port C, then do this:
int8 value;
value = input_c();
switch(value)
Look at the lcd_putc() function in the Flex driver:
case '\n':
       [b]lcd_gotoxy(1,2); [/b]
A newline causes it to set the cursor to the first position in line 2,
on a 16x2 LCD. Everytime your code has a newline (\n), that's
where the next LCD text will go. That's why it's overwriting.
PostPosted: Tue Sep 23, 2008 9:11 am     Reply with quote
case '\n':
lcd_gotoxy(1,2);
Thanks for the info. I want to make the LCD display character without overwriting previous input character. Can anybody help me?
PostPosted: Tue Sep 23, 2008 2:12 pm     Reply with quote
As explained, the newline character is your problem.
Solution:
Don't send '\n'...
PostPosted: Tue Sep 23, 2008 3:12 pm     Reply with quote
When \n removed, the character repeated and fill entire LCD.
PostPosted: Tue Sep 23, 2008 3:28 pm     Reply with quote
Solving one problem often shows you there is another problem waiting to be solved....
So now you have fixed the character being overwritten have another look at your code. You are reading PORTC, display the value and then start all over again. In other words: you are reading PORTC as fast as the processor can handle it. If you want the processor to wait for something to happen you will have to implement code for this.
You haven't told us what is connected to PORTC. Is it a keyboard? (you are including kbd44.c)
fsven
PostPosted: Tue Sep 23, 2008 4:51 pm     Reply with quote
PORTC connected to switch (binary selector) and push button. Below the image.
