Why this program doesn't work? Switch LED...
ives_13mg
PostPosted: Tue Sep 23, 2008 12:16 pm     Reply with quote
Hi. I'm confused! The pin P1C doesn´t change its state. Its state is HIGH, all the time. The PWM in P1B works but I have a problem in P1C. Why? Can you help me?
#include <16F690.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
  delay_ms(200); // power up delay
  setup_adc_ports(NO_ANALOGS | VSS_VDD);
  setup_vref(FALSE);
  setup_timer_2(T2_DIV_BY_4, 74, 1);  // 3324 Hz
  set_pwm1_duty(151L);  // 50% duty cycle
  // Enable PWM pins P1B, P1C, and P1D for output.
  // Note:  P1A is done by the compiler.
  output_low(P1B);
  output_low(P1C);
  //output_low(P1D);
  // Steer the PWM output to all four P1x pins.
  //setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_A
  //                       | CCP_PULSE_STEERING_B
  //                       | CCP_PULSE_STEERING_C
  //                       | CCP_PULSE_STEERING_D );
  setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_B);
      output_high(P1C);
      delay_ms(2000);
      output_low(P1C);
PostPosted: Tue Sep 23, 2008 12:51 pm     Reply with quote
output_high(P1C);
delay_ms(2000);
output_low(P1C);
Look closely at your LED blinking loop. How long will P1C (pin C3)
be in the "low" state ?
If you can't understand it, look at the code in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=34785
ives_13mg
PostPosted: Tue Sep 23, 2008 12:59 pm     Reply with quote
Oh thanks... Stupid question!!! I'm sorry for this..
