Verification problem with V4.074
KL
PostPosted: Fri Sep 19, 2008 10:37 am     Reply with quote
I have a program that was written and compiled with an earlier version compiler. We upgraded to V4.074 and I made a few minor changes to the code (Nothing to do with Fuse settings). When I re-compile with V4.074 and attempt to flash the processor (PIC18F6720), I receive a verification error for the configuration fuses.
Actual Expected
CCP2C1 CCP2C1
RESERVED
STVREN STVREN
Where "RESERVED" is in red
Actual Data (Hex) 00 22 0E 0E 83 01 81 00 FF C0 00 E0 FF 40
Expected Data (Hex) 00 22 0E 0E 83 03 81 00 FF C0 00 E0 FF 40
What do I need to do to correct this problem?
Thank you for the input.
PostPosted: Fri Sep 19, 2008 6:56 pm     Reply with quote
The 03 value seems correct, see the datasheet Table 23-1, note 3.
3: Unimplemented in PIC18FX620 and PIC18FX720 devices; maintain this bit set.
But... Register 23-5, note 1 (page 240) mentions:
Note 1: Unimplemented in PIC18FX620 and PIC18FX720 devices; read as ‘0’.
So the documentation on this bit is confusing. I'm not sure what the correct value should be.
You didn't mention the fuses you have set in your program so I used the following configuration for testing:
#fuses HS,NOWDT,PUT, NOPROTECT, NOLVP
My v4.077 generates the same 0x01. I don't have the latest compiler release so can't check if it has been changed.
What was the version number of this old compiler? I tried with v3.249 and v4.038 but both versions generate a 0x01 instead of 0x03.
Which programmer are you using? ICD2, UCD40, etc?
Which IDE are you using? CCS, MPLAB, etc? And what version number?
A workaround:
If you have the CCS Windows compiler version you can use the Chipedit program to change the configuration fuses. Chipedit is available in the IDEUTILS package from the websites download section.
Select the PIC18F6720 device and in the top-right table change the fuse setting:
           MASK VALUE CW
RESERVED   0200  0000  3    to  0200 0200 3
