MPLAB/CCS
MPLAB/CCS
PostPosted: Fri May 30, 2008 4:07 am     Reply with quote
I am trying to run CCS version 4.071 from within MPLAB 8.00.
When I try to build I get an error saying CCS compiler not installed on this machine.
CCS is installed and works fine.
Any ideas?
Best regards,
CCS
PostPosted: Fri May 30, 2008 11:07 am     Reply with quote
You need to download and install the MPLAB plug-in. Visit http://www.ccsinfo.com/downloads.php
MPLAB/CCS
PostPosted: Fri May 30, 2008 12:00 pm     Reply with quote
Thanks for the reply, but I have done what you suggest.
PostPosted: Fri May 30, 2008 12:07 pm     Reply with quote
Look at the column headings on this table. It lists the different types
of CCS compilers. Which one do you have ? Or do you have the demo ?
http://www.ccsinfo.com/content.php?page=ideoverview
MPLAB/CCS
PostPosted: Fri May 30, 2008 1:30 pm     Reply with quote
Looking in Help, About I have CCS PCWH version 4.071.
In 'project', 'select language toolsuit' I have C:\Program Files\PICC\Pcw.exe.
Regards
PostPosted: Fri May 30, 2008 1:59 pm     Reply with quote
I think that line should look like this:
C:\Program Files\PICC\Ccsc.exe
Make sure you read this FAQ article on installing and using CCS
with MPLAB:
http://www.ccsinfo.com/faq.php?page=ccs_mplab
Here are some more links:
Answer to a recent question to use multiple source files with MPLAB:
http://www.ccsinfo.com/forum/viewtopic.php?t=34046
More detailed information on using multiple files with MPLAB.
Read all the links in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=32221
How to debug CCS code in MPLAB with the ICD2:
http://www.ccsinfo.com/forum/viewtopic.php?t=33505
Error : " Unknown device type -- Try PCH"
PostPosted: Tue Sep 16, 2008 9:17 pm     Reply with quote
I am trying to run CCS version 4.038 from within MPLAB 7.50
When I compile code for pic18F2450, appear error: "Unknown device type -- Try PCH"
Then I replace code for pic18f452, appear error: "Unknown device type -- Try PCH" too.
Can you say to me about this problem!
#include <18F2450.h>
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
      set_tris_b(0);
         output_low(PIN_B1);
         output_high(PIN_B1);
PostPosted: Wed Sep 17, 2008 5:28 pm     Reply with quote
From the error message it looks like you are using the wrong compiler version.
The CCS compiler comes in different flavours for the different PIC families:
PCB for PIC12
PCM for PIC16
PCH for PIC18
PCD for PIC24 and dsPic
These are all command line tools. The Windows versions have similar names but with the character W added. For a complete overview see: http://www.ccsinfo.com/content.php?page=ideoverview
If you do have the correct compiler version then your mistake was you forgot to tell MPLAB which processor you are using: in MPLAB select 'Configure / Select device ... ' and select here your processor type.
quocloc.pham
Re: Error : " Unknown device type -- Try PCH"
PostPosted: Wed Sep 17, 2008 7:53 pm     Reply with quote
PCB for PIC12
PCM for PIC16
PCH for PIC18
I don't think so that! because I use CCS PCH compiler (ccsc v4.038)
and I don't forget tell MPLAB which processor I using.
quocloc.pham
No error " Unknown device type -- Try PCH"
PostPosted: Wed Sep 17, 2008 9:42 pm     Reply with quote
PCB for PIC12
PCM for PIC16
PCH for PIC18
I was configure the same you said, the compiler had already done!
Thanks a lot!!
