mymadi
| Xbee API Method |
Posted: Wed Sep 17, 2008 2:08 am |
Dear all
I wrote a source code for Xbee transceiver. I'm using API methods. Luckily, it is working. But, may be my code is look funny. Here i show my source code:
Transmit Request 16-bit:
void GXBeeTR()
unsigned int8 sd,lmsb,llsb,id,fid,damsb,dalsb,op,gid,data,csm;
sd = 0x7E; // (Byte 1)Start Delimiter
lmsb = 0x00; // (Byte 2)Length MSB
llsb = 0x07; // (Byte 3)Length LSB
id = 0x01; // (Byte 4)API Identifier
fid = 0x00; // (Byte 5)Frame ID
damsb = 0x71; // (Byte 6)Destination Address MSB
dalsb = 0x76; // (Byte 7)Destination Address LSB
op = 0x00; // (Byte 8)Options (Please Refer Datasheet)
gid = 0x02; // (Byte 9)G-Xbee ID
data = value00; // (Byte 10)Gas Sensor Value
// (Byte 11)Checksum
csm = 0xFF - (id + fid + damsb + dalsb + op + gid + data);
putc(sd);putc(lmsb);putc(llsb);putc(id);putc(fid);putc(damsb);
putc(dalsb);putc(op);putc(gid);putc(data);putc(csm);
Receive Packet 16-Bit:
void GXBeeRP()
unsigned int8 x;
chksumRP = 0;
for (x=1;x<=11;x++)
byteRP[x]=getc();
chksumRP = chksumRP + byteRP[4] + byteRP[5] + byteRP[6] + byteRP[7] + byteRP[8] + byteRP[9] + byteRP[10];
chksumRP = 0xFF - chksumRP;
CheckRP();
Can anyone help me to minimize the source code for both Transmit and Request?
Thank You |
tottidatunisia
| Re: Xbee API Method |
Posted: Sat May 12, 2012 11:09 am |
| the gas sensor that you use have a profile home automation or not? |
ezflyr
Posted: Sat May 12, 2012 2:58 pm |
Do you realize that this thread is almost 4 years old???
John |
