Help on segmented LCD
Goto page Previous  1, 2, 3  Next
PostPosted: Fri Sep 12, 2008 11:48 am     Reply with quote
I have PCM Ver 3.249
PostPosted: Fri Sep 12, 2008 12:17 pm     Reply with quote
In vs. 3.249 they didn't have the LCD_BIAS_PINS constant in the
16F917.H file. They added it later in vs. 4.xxx. All the rest of the
LCD constants in the .H file are the same in both versions.
Maybe during the weekend I'll look at it and see what's necessary
to add support for the 1st digit (which can only display '1').
PostPosted: Mon Sep 15, 2008 3:16 pm     Reply with quote
How to put all 4 digits on to the LCD ?
I'm working on this problem.
I don't have the PicDem Mechatronics board, so I can't physcially test
the code. I have a question. When you run the driver and the test
program that I posted earlier in this thread, what does it display on
the LCD ? Post what you see.
PostPosted: Tue Sep 16, 2008 7:41 am     Reply with quote
If comment out like this
setup_lcd(LCD_MUX14, 0); // | LCD_BIAS_PINS, 0);
I can compile it and "432" show on the LCD instead of "234"
PostPosted: Tue Sep 16, 2008 11:13 am     Reply with quote
I always thought those digits were reversed, but the person I was working
with at the time, said everything was OK. I don't have the Mechatronics
board and you can't buy the VIM-332-DP LCD (apparently), so I could
never test it in hardware.
Your version of the compiler is missing this #define statement from
the 16F917.H file. Just add the following line to the program. Put it
in the area below the #use delay() statement, where the other #define
statements are located.
#define LCD_BIAS_PINS     0x10
The code below should work better. I've corrected the reversed digits
problem and I've added support for the left-most digit ("1").
#include <16F917.H>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, PUT
#use delay(clock=8000000)
// The LCD digits are numbered in the following way,
// according to the Varitronix VIM-332-DP data sheet.
//            _    _    _
//        |  |_|  |_|  |_|
//        |  |_|  |_|  |_|
// Digit  4   3    2    1
// The CCS lcd_symbol() function will be used to display digits
// 1, 2, and 3. The following define statements tell the
// lcd_symbol() function which PIC pins are connected to the
// LCD segment pins.
// There is a table on page 58 of the PicDem Mechatronics
// Demonstration Board data sheet which lists the connections
// that are used to make these define statements.
// Digit segments  A        B        C        D        E        F        G        DP
//                 b7       b6       b5       b4       b3       b2       b1       b0
#define DIGIT3  COM0+3,  COM0+11, COM2+11, COM3+3 , COM2+3,  COM1+3,  COM1+11, COM3+2
#define DIGIT2  COM0+6,  COM0+21, COM2+21, COM3+6,  COM2+6,  COM1+6,  COM1+21, COM3+11
#define DIGIT1  COM0+22, COM0+23, COM2+23, COM3+22, COM2+22, COM1+22, COM1+23, COM3+21
// The following array tells the CCS lcd_symbol() function which
// segments to turn on, to display the numbers from 0 to 9.
//                            0    1    2    3    4    5    6    7    8    9
byte const Digit_Map[10] = {0xFC,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xE6};
#define BLANK 0  // For a blank digit, don't turn on any segments.
#byte LCDDATA6 = 0x116
#bit  seg_4bc = LCDDATA6.2   // Controls left-most digit ("1")
int8 lcd_pos;
void lcd_putc(char c)
int8 segments;
if(c == '\f')
   lcd_pos = 0;
   if((c >= '0') && (c <= '9'))
      segments = Digit_Map[c - '0'];
      segments = BLANK;
   switch(lcd_pos)
      case 1:           // 1000's digit (left-most digit on lcd)
        if(c == '1')        // Is the top digit = 1 ?
           seg_4bc = 1;     // If so, display it
        else                // If it's not = 1, don't display it.
           seg_4bc = 0;
      case 2: lcd_symbol(segments, DIGIT3); break; // 100's digit
      case 3: lcd_symbol(segments, DIGIT2); break; // 10's digit
      case 4: lcd_symbol(segments, DIGIT1); break; // 1's digit
lcd_pos++;
int16 number;
setup_lcd(LCD_MUX14 | LCD_BIAS_PINS, 0);
number = 1234;
printf(lcd_putc,"\f%4lu",number);   // Always send 4 digits
Last edited by PCM programmer on Tue Sep 16, 2008 11:33 am; edited 1 time in total
PostPosted: Tue Sep 16, 2008 11:28 am     Reply with quote
Thanks...
It works like a champ!
PostPosted: Tue Sep 16, 2008 11:36 am     Reply with quote
I added a comment in my post about adding the LCD_BIAS_PINS
definition to your program. That's in there because the demo program
from Microchip (written in MPASM) has the bias pins enabled. So
supposedly they think it's necessary.
PostPosted: Tue Sep 16, 2008 1:04 pm     Reply with quote
I try to understand the following
Can you explain how these work relate to LCD?
Sorry, I new to this. I try to compare your line above to the mapping worksheet that came with the demo board and still don't get it. Again what is COM0+22 and etc.?
PostPosted: Tue Sep 16, 2008 1:30 pm     Reply with quote
I assume you're looking at the chart on page 58 (page 62 in Acrobat
reader) in the PicDem Mechatronics Demonstration Board User's Guide:
http://ww1.microchip.com/downloads/en/DeviceDoc/51557C.pdf
Here's the Varitronix VIM-332 LCD data sheet:
http://www.varitronix.com/Product/LCD/VIM-332-DP(R0).pdf
Look at page 2. It shows the digit numbers. Digit #1 is on the right side.
Now look at page 3. It shows the segment letters. Segment "A" is at
the top of each digit.
Now look at the chart on page 58 of the Mechatronics User's Guide again.
Down near the bottom left corner, you can see segment "1A". Notice
that segment "1A" corresponds to "COM0" and "SEG22".
That's how we get the first item in this #define statement.
Notice the next item above is "COM0+23". Go look in the chart in the
User's Guide for segment "1B". Notice that it is in the column for COM0
and it's in the row for SEG23. That's how the chart can be converted to
the CCS #define statements.
This only works for the digits. For individual feature symbols, such as
a "Diode" or "BATT", you have to turn them on/off individually, with lines
of code.
newpic
PostPosted: Wed Sep 17, 2008 2:20 pm     Reply with quote
PCM Programmer,
Any sample code to turn on the battery icon?
You have mentioned that need individual lines to turn these. Can you give sample code?
Thank you
PostPosted: Wed Sep 17, 2008 3:29 pm     Reply with quote
To add support for the symbols, you need to do this:
1. Add #byte statements to your program that declare the addresses of
all the LCDDATA registers.
2. Add macros that allow individual bits of the LCDDATA registers to be
set or cleared. There will be one macro per symbol. The reason for
using macros instead of functions is that it takes only one line of source
code to write it, and it compiles to only 1 or 2 lines of ASM code.
Let's do the "Diode" symbol on the Mechatronics LCD.
First, look at the Varitronix LCD data sheet, and find the name that
they give to the "Diode" symbol. It's in the upper right corner of the
diagram on page 2. They call it "S2".
Now look at the Mechatronics User's Guide. Look at the table
on page 58 (page 62 in the Acrobat reader). This table shows
what bit of each LCDDATA register is assigned to each segment
or symbol on the Mechatronics LCD. You can see that "S2" is in
the 2nd column, and it's assigned to bit 0 of the LCDDATA5 register.
Now you have enough information to write the code.
First, look at the SFR register addresses in the 16F917 data sheet.
Create all the byte statements that declare the register addresses.
#byte LCDDATA0  = 0x110
#byte LCDDATA1  = 0x111
#byte LCDDATA2  = 0x112
#byte LCDDATA3  = 0x113
#byte LCDDATA4  = 0x114
#byte LCDDATA5  = 0x115
#byte LCDDATA7  = 0x117
#byte LCDDATA8  = 0x118
#byte LCDDATA9  = 0x119
#byte LCDDATA10 = 0x11A
#byte LCDDATA11 = 0x11B
Now write the macro for the diode symbol. The parameter 'x' will be
either TRUE or FALSE. In C, a "true" value is one that is non-zero.
So we can use a "conditional" test to check if 'x' is non-zero. If it is,
then set the LCDDATA5.0 bit. If 'x' is zero, then clear the bit:
#define display_diode(x) x ? bit_set(LCDDATA5, 0) : bit_clear(LCDDATA5, 0)
Then in your program, to turn on the Diode symbol, you would do this:
display_diode(TRUE);
To turn it off, you do this:
display_diode(FALSE);
In a similar way, you can do the "BATT" symbol. From the Mechatronics
data sheet table, you can see that it's assigned to LCDDATA3, bit 1.
So the macro would look like this:
#define display_batt(x)  x ? bit_set(LCDDATA3, 1) : bit_clear(LCDDATA3, 1)
newpic
PostPosted: Fri Sep 19, 2008 1:30 pm     Reply with quote
It does not work. The diode will not turn on.
Here is my code.
#include <16F917.H>
#device ICD=TRUE ADC=10
   int16 number,result;
   float temp;
      delay_ms(5000);
      delay_ms(5000);
//      display_batt(TRUE);
PostPosted: Fri Sep 19, 2008 2:12 pm     Reply with quote
That's because the segment drivers are not enabled for the symbols.
I didn't realize this. The CCS routines only turn on the segments
that are specified when the lcd_symbol() function is called. For the
symbols, we need to separately enable the segment drivers with
our own code.
I don't have a Mechatronics board to test, and Digikey and Mouser
(the two main Varitronix LCD distributors) don't sell the VIM-332 LCD.
So I depend upon you to test the code.
To turn on the segment drivers for the symbols, you need to add this
code above main().
#bit SEG0 = LCDSE0.0
#bit SEG1 = LCDSE0.1
#bit SEG16 = LCDSE2.0
#define enable_symbol_segments(x) SEG0 = x; SEG1 = x; SEG16 = x
Then in main(), add the following line after the call to setup_lcd().
enable_symbol_segments(TRUE);
This will turn on the 3 segment drivers for all symbols. According to
the table at the end of the Mechatronics User's Guide, the symbols are
all on SEG0, SEG1, or SEG16. So this should work.
newpic
PostPosted: Wed Jan 19, 2011 8:57 pm     Reply with quote
I will try it.
pic_micro
how to display diode symbol onMechatronic board
PostPosted: Mon Feb 07, 2011 3:26 pm     Reply with quote
Dear PCM:
I've tried your code per the above instruction, when compile, I got these errors.
Executing: "C:\CCS_PIC\PCM\PICC\Ccsc.exe" "ex3.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
*** Error 12 "C:\chai\CProjects\PICC Experiment\CCS\mechatronic\ex3\ex3.c" Line 24(2,5): Undefined identifier   ?
*** Error 48 "C:\chai\CProjects\PICC Experiment\CCS\mechatronic\ex3\ex3.c" Line 24(11,15): Expecting a (
*** Error 48 "C:\chai\CProjects\PICC Experiment\CCS\mechatronic\ex3\ex3.c" Line 24(13,19): Expecting a (
*** Error 12 "C:\chai\CProjects\PICC Experiment\CCS\mechatronic\ex3\ex3.c" Line 29(1,35): Undefined identifier   ?
*** Error 12 "C:\chai\CProjects\PICC Experiment\CCS\mechatronic\ex3\ex3.c" Line 36(29,30): Undefined identifier   SEG0
*** Error 12 "C:\chai\CProjects\PICC Experiment\CCS\mechatronic\ex3\ex3.c" Line 36(29,30): Undefined identifier   SEG1
*** Error 12 "C:\chai\CProjects\PICC Experiment\CCS\mechatronic\ex3\ex3.c" Line 36(29,30): Undefined identifier   SEG16
      7 Errors,  0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Mon Feb 07 16:18:18 2011
See my code below:
File Name: ex3.c
#include <mechatronic.h>
   unsigned int16 value;
   unsigned int temp;
   // initial lcd
   // setup adc
   setup_adc(ALL_ANALOG);
   setup_adc( ADC_CLOCK_INTERNAL );
   set_adc_channel(0);
      delay_ms(1);
      value = read_adc();
   //   value = 1234;
      temp =  (value/2) - 50;
         delay_ms(5000);
      printf(lcd_putc,"\f%u",temp);   // Always send 4 digits
File name: mechatronic.h
File name mechatronic.h, it is an include file
#include <16F917.H>
#include <mech_seg_driver.c>
#define SW2   PIN_A4
#define SW3   PIN_A5
#define   LED   PIN_D7
//#byte d_port = 0x08
#bit LED2 = 0x08.7
File name: mech_seg_driver.c>
FILE NAME mech_seg_driver.c
It is the LCD driver for LCD VIM-332-DP that mount on the
mechatronic board
//            _    _    _
//        |  |_|  |_|  |_|
//        |  |_|  |_|  |_|
// Digit  4   3    2    1
int8 lcd_pos;
int8 segments;
if(c == '\f')
   lcd_pos = 0;
      segments = BLANK;
   switch(lcd_pos)
           seg_4bc = 0;
lcd_pos++;
Please help me..
Page 2 of 3
