| delphy_boy
				| I2C hardware module issue |
				|  Posted: Mon Sep 15, 2008 4:29 am |   |
				| Hi,
 Does anyone know why my program hangs when using the I2C harware functions on a PIC18F6722?
 When I try to do an I2C start the program just hangs.
 Here is the code
  	  | Code: |  	  | #use delay(clock=3684000)
 #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=GUI,errors)
 #use i2c(master, sda=PIN_C4, scl=PIN_C3, stream=ONE, FORCE_HW)
 #use i2c(master, sda=PIN_D5, scl=PIN_D6, stream=OTHER, FORCE_HW)
 void initialise_ADC()
 i2c_start(ONE);//initiate a start condition
 output_low(PIN_C0);
 i2c_write(ADC_WRITE_ADDR);//send device write address
 i2c_write(ADC_SET_CONVERT);//set ADC configuration
 i2c_stop();//terminate comms
