help about serial port monitor
LOGIC_ELECTRONICS
PostPosted: Mon Sep 15, 2008 3:41 am     Reply with quote
HI
I have a project about (PIC16F876, LCD, KEYPAD and SERIAL). I want to display data transferred from terminal to PC on serial port monitor of PCW. How I do that ?
thanks
PostPosted: Mon Sep 15, 2008 2:07 pm     Reply with quote
This line is used to setup the "pin B3" debug monitor for the CCS IDE.
This feature only exists if you have PCW, PCWH, or PCWHD.
#use RS232(DEBUGGER)
This thread has an example of how to use it in a program:
http://www.ccsinfo.com/forum/viewtopic.php?p=37113
Also see this post about using the Debug monitor with streams:
http://www.ccsinfo.com/forum/viewtopic.php?t=30686
This page shows that pin B3 on the PIC must be connected to pin 6 on
the ICD connector, to use the debug monitor with the CCS IDE:
http://www.ccsinfo.com/faq.php?page=icd_connection
Rod Gilchrist
PostPosted: Wed Oct 22, 2008 12:56 pm     Reply with quote
Also, you need to select 'Userstream enabled true' on the 'Debug Configure' window. This is with PCW version 4.079 anyway.
