ACS712 Help
BOB_SANTANA
ACS712 Help
PostPosted: Sun Sep 14, 2008 11:34 am     Reply with quote
Hi All
I just need to pick your brain once more .
i am using the ACS712 to measure a current 0-1A and the device is working but i need to know how i can remove the 2.5v offset because when i applied my load the voltage out is only about 2.8V
Is there a way i can remove this offset
http://www.allegromicro.com/en/Products/Part_Numbers/0712/index.asp
BOB_Santana Smile
PostPosted: Sun Sep 14, 2008 12:24 pm     Reply with quote
By design, the ACS sensors (as other manufacturers current sensors, too) have a bipolar output range with a midscale zero. The most simple way is to substract the offset measurement from result. Alternatively, an analog preprocessing with a differential amplifier could increase the resolution.
But as far as I see from the datasheet, the sensor noise has already a magnitude of several LSB in 10 bit ADC mode without additional gain, thus an additional amplification would be only meaningful with a strong low pass filtering.
BOB_SANTANA
PostPosted: Sun Sep 14, 2008 2:50 pm     Reply with quote
Yes thanks for that.
But for my application I am not reading the voltage from the sensor
to the A/D of the Pic.
What I intend to do is to read the current being sent from the sensor but with the sensitivity cranked up ... the output will be "High" (output saturated) with any current being drawn, and "Low" when there's no current.
This way I can then feed it to the PIC via a schmit trigger.
BOB_Santana Smile
PostPosted: Sun Sep 14, 2008 3:45 pm     Reply with quote
In this case, a comparator with an exactly dimensioned voltage divider for the threshold would be needed.
PostPosted: Mon Sep 15, 2008 10:35 am     Reply with quote
are there any examples anywhere i can have a look at?
Bob
PostPosted: Wed Sep 17, 2008 1:11 pm     Reply with quote
Anyone know if this can done with the LM311N as I have a few at home.
BOB_SANTANA
PostPosted: Wed Sep 17, 2008 1:15 pm     Reply with quote
I am not sure how to use the Balance/strobe pins.
Can you help ?
Regards
Bob
BOB_Santana Smile
