delay_ms and int16
Ringo42
delay_ms and int16
PostPosted: Sun Sep 14, 2008 2:40 pm     Reply with quote
I'm using an int16 variable in Delay_ms.
If I use V3.249 then it does not seem to work with numbers bigger than 255.
If I use 4.007 then it just seems to delay forever. Is this the correct behavior for 3.249? I think it is but the current manual says it should work with an int16, not just an int8.
So assuming that 4.007 is too crappy, is there an easy way to use delay_ms with numbers bigger than 255? I can make a loop and have it execute over and over again, but if there is a neater way I'd like to know.
Ringo
Ringo Davis
PostPosted: Sun Sep 14, 2008 2:45 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=32288
Ringo42
PostPosted: Sun Sep 14, 2008 2:49 pm     Reply with quote
Thanks, That is much simpler that what I was thinking.
Ringo
Ringo Davis
