c code of pic18f4431 not working
lgeorge123
PostPosted: Sat Sep 13, 2008 8:54 am     Reply with quote
I wrote a C code of pic18f4431 and compiled success. Turn on the power I only see the PWM1 has 5v. PWM0 has 0v. the code is as follows:
Can someone help me !!!
#include <18f4431.h>
#device ADC=8
#fuses HS,NOWDT,nolvp
#use delay (clock=20000000)
#use fast_io(A)
#use fast_io(B)
 // setup_comparator(NC_NC_NC_NC);
//setup_vref(0);
  set_tris_a(0b11111111);         // A2-3 outputs
  //set_tris_b(0b11010100);      // B0-1,B3,B5 outputs
set_power_pwm_override(0, false, 1);
setup_power_pwm(PWM_CLOCK_DIV_4 | PWM_FREE_RUN |
PWM_DEAD_CLOCK_DIV_4,1,10000,1000,0,1,0);
setup_power_pwm_pins(PWM_COMPLEMENTARY ,PWM_OFF, PWM_OFF, PWM_OFF);
set_power_pwm0_duty(4000);
PostPosted: Sat Sep 13, 2008 11:38 am     Reply with quote
Post your compiler version.
Unless somebody else helps you first, I can't work on this until tomorrow.
lgeorge123
PostPosted: Sun Sep 14, 2008 3:45 am     Reply with quote
I use 4.074 version.
PostPosted: Sun Sep 14, 2008 10:29 am     Reply with quote
The override won't work. You have the PWM in 'complementary' mode. Look at the note in Figure 17-2 of the data sheet. remember that '0' is an 'even' number as far as channel numbers are concerned.
I think what is happening, is that the compiler is trying to handle this override, and is automatically applying it to channel one instead, which in complementary mode, results in PWM0=0 PWM1=1.
