!!! Help me with PWM !!!
hubble
PostPosted: Sat Sep 13, 2008 9:15 am     Reply with quote
How can I get next graphs?
1. on CCP1 - PWM in odd period;
2. on CCP2 - PWM in even period.
Graphic and code below:
CCP1  _|''''|________________________|''''|______________
CCP2  _______________|''''|__________________________|''''|___
      |<-1st period->|<-2nd period-> | <-3rd period->|
#include <16F886.h>
#device  ADC=10
#fuses HS,NOWDT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
#define PR2  49   // 20kHz
//!#byte PWM1CON = 0x9B
#byte CCP1CON = 0x17
#byte CCP2CON = 0x1D
int16 currentDuty;
#int_timer2
void Interrupt_RTCC()
int8 changeCCP;
   changeCCP^=1;
   if(changeCCP)
      set_pwm1_duty(currentDuty);
      set_pwm2_duty(currentDuty);
int16 oldDuty;
setup_port_a(ALL_ANALOG);
setup_adc(adc_clock_internal);
set_adc_channel(0);
set_tris_b(0xff);
set_tris_c(0xff);
CCP1CON=0b00101100;
CCP2CON=0b00101100;
//!PWM1CON=0b00000010;
setup_timer_2(T2_DIV_BY_1,PR2,1);
set_tris_b(0);
set_tris_c(0);
output_c(0);
      currentDuty=read_adc();
      if (oldDuty!=currentDuty){
         currentDuty=currentDuty*(PR2+1)/255;
//!         set_pwm1_duty(currentDuty);
//!         set_pwm2_duty(currentDuty);
         oldDuty=currentDuty;
      delay_ms(10);
It works, but not what I wanted Sad
Help me with question.
Thank beforehand.
PostPosted: Sat Sep 13, 2008 11:25 am     Reply with quote
Read this thread about using the CCP in Compare Mode instead of PWM
mode. This will allow you do a phase shift between the signals:
http://www.ccsinfo.com/forum/viewtopic.php?t=30607
PostPosted: Sat Sep 13, 2008 3:34 pm     Reply with quote
Thank you PCM programmer.
It works.
But if I change the next variable
#define PWM_PERIOD 1000L
#define PULSE_ON_TIME 250L
to (for example)
#define PULSE_ON_TIME 50L
or to (for example too)
#define PWM_PERIOD 250L
#define PULSE_ON_TIME 150L
then I have bad (very bad) graphs on me oscilloscope.
What`s wrong?
Can you help me again?
RLScott
PostPosted: Sat Sep 13, 2008 7:00 pm     Reply with quote
Anonymous wrote:
...But if I change the next variable
to (for example)
50 is probably too short for the interrupt service routine.
This leaves pulse_off_time equal to 100, which might also be too short for the interrupt service routine.
One way to speed up the interrupt service routine from the one posted in the referenced thread is to replace the setup_ccp1 and setup_ccp2 functions with a single bit setting or bit clearing instruction that does the same thing.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
