How to interface magnetic card reader with PC
Goto page 1, 2  Next
asimraufawan
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Sat Jul 05, 2008 3:33 am     Reply with quote
HI ALL!
I am new to this forum.
Actually I want to interface the TTL magnetic card reader with computer
I have tried it with stripe snoop using game port but it does not work out
the reader i m using is TYSSO TTL MCR series which reads data from track 2 with loco magnetic cards, now i m a little bit confused how will i interface it with serial port, in the reader there is a decoder IC ET6106
which decode the magnetic head analog signal to digital form which output three signals which are CARD PRESENT(/CLS) ,DATA(/RDP) & STROBE or CLOCK PULSE (/RCP).
Kindly help me out,
Thanks,
ASIM RAUF
dyeatman
PostPosted: Sat Jul 05, 2008 7:14 am     Reply with quote
A search of this forum would be a good place to start.
Find the MCR.C driver that comes with the compiler then see the below links.
http://www.ccsinfo.com/forum/viewtopic.php?t=34383
http://www.ccsinfo.com/forum/viewtopic.php?t=34716
Dave
asimraufawan
PostPosted: Wed Jul 09, 2008 1:45 am     Reply with quote
I have gone through both the links below plus mcr.c driver
still confused what will be the hardware design.
PostPosted: Wed Jul 09, 2008 11:48 am     Reply with quote
Just to make sure, do you want to connect the MCR reader to the PC or to a PIC? It's only one letter difference so it could be a typing error.
As I see you posted the same question in at least three other forums not related to the PIC my guess is you intend to read the data with a PC? Please note that this forum is dedicated to the PIC processor and that we don't know a lot about PC interfacing.
Here is a link to a website with several Tysso card readers: http://www.barcode-manufacturer.com/magnetic_card/magstripe.html#OEM_Modules
Which is the one you are using?
asimraufawan
PostPosted: Thu Sep 04, 2008 11:19 pm     Reply with quote
I posted the question on other forums so that i can collect many ideas
now i decided to see the result of card reader on PC by using PIC16F877A.
Simply by connecting the magnetic card reader to PIC then PIC to thePC via RS232.
can any one provide me the sample code.
n-squared
PostPosted: Fri Sep 05, 2008 8:34 am     Reply with quote
Did you purchase a CCS compiler? It contains a ready made code for reading tracks 1 and 2.
Every solution has a problem.
asimraufawan
PostPosted: Sat Sep 06, 2008 12:13 am     Reply with quote
Thanks,
i just want to read track 2 data,
this example for reading data from MCR hope will work fine.
PostPosted: Sat Sep 06, 2008 2:23 am     Reply with quote
In terms of hardware, all you need is the normal MAX232 RS232 driver IC (or something else similar), wired just as you would to talk to a PC, _except_ with pins2,and 3 'swapped' on the DB9 connection. Basically the modules are wired to talk to a PC, so the TXD, and RXD connections need to be swapped.
asimraufawan
PostPosted: Fri Sep 12, 2008 12:34 am     Reply with quote
sorry i didnt get the above point
PostPosted: Fri Sep 12, 2008 2:33 am     Reply with quote
The module is wired so that it's RXD line connects to a PC's TXD line, and vice versa. The normal PIC RS232, is _wired the same way_, so that it too can talk directly to a PC. To talk to the module, you either need a 'null modem' cable (that swaps these lines), or to swap the wiring on the PIC connections.
asimraufawan
PostPosted: Fri Sep 12, 2008 9:41 pm     Reply with quote
It works fine when i connect first time to the hyper terminal but when i disconnect & then reconnect in the same window it works but show the data twice of each card some time mix the data of different magnetic cards.
Kindly explain the PARITY & LRC error regarding the magnetic cards
as well as where will i find a flow diagram for the whole process.
THANKS
asimraufawan
PostPosted: Fri Sep 26, 2008 12:32 am     Reply with quote
I m just reading the data from track 2 ,therefore i made the mcr.c driver
& example file for the particular task,
#include <16F877A.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
#ifndef MCR_CARD_PRESENT
#define MCR_CARD_PRESENT   PIN_B0
#define MCR_DATA          PIN_B4
#define MCR_STROBE        PIN_B5
#define MCR_ERR_PARITY 2
#define MCR_ERR_LRC    8
int mcr_read(char* track2)
   int   error    = 0;
   int1  dataBit  = 0;
   int1  ST       = 1;
   int1  ST_old   = 1;
   int1  firstOne = 0;
   int1  parity   = 0;
   int   count    = 0;
   int   index    = 0;
   int   LRC      = 0;
   // Wait for card to be present
   while(input(MCR_CARD_PRESENT));
   // Loop until a card is not present
   while(!input(MCR_CARD_PRESENT))
   // Check for NULL pointer and an index less than 40
      if(track2 != 0 && index < 40)
         // Get strobe
         ST = input(MCR_STROBE);
         // If the strobe was high and is now low (falling edge),
         //then data is present
         if(ST == 0 && ST_old == 1)
            ST_old = 0;
            // Check if the first 1 was received
            if(firstOne == 1)
               // Check if 4 bits of data were received
               if(count == 4)
                  // Reset the bit counter back to 0
                  count = 0;
                  // Shift the bits right by 4
                  *(track2+index) >>= 4;
                  // Verify the LRC
                  if(*(track2+index-1) == '?' && LRC != *(track2+index))
                     error |= MCR_ERR_LRC;
                     LRC ^= *(track2+index);
                  // Add 0x30 to convert to ASCII
                  *(track2+index) += 0x30;
                  // Check the parity bit. The parity on a 0 is not checked
                  // because of the trailing zeros after the LRC character
                  if(!input(MCR_DATA) != parity && *(track2+index) != '0')
                     error |= MCR_ERR_PARITY;
                  // Reset the parity check
                  parity = 1;
                  // Increment the index into the array
                  ++index;
                  // Get a bit of data from the card
                  dataBit = !input(MCR_DATA);
                  // XOR the data with the parity bit
                  parity ^= dataBit;
                  // Store the new bit of data
                  shift_right(track2+index, 1, dataBit);
                  // Increment the bit counter
                  ++count;
               // Check if the first 1 has appeard on the data line
               if(!input(MCR_DATA))
                  // Set the first 1 received flag
                  firstOne = 1;
                  // Store the first 1
                  shift_right(track2, 1, 1);
                  ++count;
         else if(ST == 1)
            ST_old = 1;
   // Return any errors
   return error;
   int index;
   int error;
   char Track2[40];
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // TODO: USER CODE!!
      printf("\r\n\nWaiting to read magnetic card...\r\n");
      // Read a card and get any errors
      error = mcr_read(Track2);
// Display the data in track 2
      index=0;
      printf("\r\nTrack2 Data:\r\n");
      // Loop until the end sentinel (?) is displayed.
      // This loop does not display the LRC character.
      do
          //Display the character and increment the index
         putc(Track2[index++]);
      while(Track2[index-1] != '?' && index<40);
      // Check for card reading errors
      if(error & MCR_ERR_PARITY)
         printf("\r\nTrack 2 parity error");
      if(error & MCR_ERR_LRC)
         printf("\r\nTrack 2 LRC error");
In short i m drawing a flow chart for the above program
as for future reference but in function i m not getting how to
describe the flow for LRC & PARITY error verification can any
one explain me in detail.
Below is the part for LRC & PARITY error.
            ST_old = 0;
            if(firstOne == 1)
               if(count == 4)
                  count = 0;
                  // Verify the LRC
                  parity = 1;
                  ++index;
THANKS
n-squared
PostPosted: Sun Sep 28, 2008 3:59 pm     Reply with quote
The exact description and good explanations for magnetic card reading can be found in the ISO7811 standard.
There should be no problem getting this document on the internet.
Best regards
dsolorzano
PostPosted: Tue Mar 29, 2011 1:56 am     Reply with quote
Hello. The mcr library is very nice. However I need to do a bidirectional code and have been unable to do it. Could anybody help me? Thanks
PostPosted: Tue Mar 29, 2011 3:12 am     Reply with quote
Please, for a new question start a new thread. Do not re-open a three year old topic for a question that has almost no relation to the original question.
Goto page 1, 2  Next
Page 1 of 2
