using portA with flex_lcd
Salenko
PostPosted: Wed Sep 10, 2008 12:38 pm     Reply with quote
Hi all,
can anybody tell me why I failed to use the PortA to drive the LCD (using flex_lcd.c driver)?
-this is my main progam:
#include <16F876.H>
#use delay(clock = 4000000)
#include "flex_lcd.c"
byte byte_b;
//T0CS = 0
set_tris_a(0);
set_tris_b(0xff);
   setup_timer_1(T1_DISABLED);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
byte_b=input_b();
if (byte_b==0x01)      // start the LCD with a push-botton connected to RB0
    lcd_init();  // Always call this first.
    lcd_putc("\fHello World\n");
    lcd_putc("Line 2.");
changes in flex_lcd.c:
(I only changed the pins to fit my board and commented out #define USE_LCD_RW 1 as written in the comments.
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver.  Change these
// pins to fit your own board.
#define LCD_DB4   PIN_A0
#define LCD_DB5   PIN_A2
#define LCD_DB6   PIN_A4
#define LCD_DB7   PIN_A5
#define LCD_E     PIN_A1
#define LCD_RS    PIN_A3
//#define LCD_RW    PIN_A2
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
//#define USE_LCD_RW   1
this is a printscreen from the simulation (before activating the LCD)
printscreen when the LCD is activated (but no display !- notice the changements in portA pins)
thanks for any kind of help.
Rq :I have read the I/O section of the 16F876 datasheet before asking
PostPosted: Wed Sep 10, 2008 12:54 pm     Reply with quote
The contrast pin on the LCD is not connected to anything.
Try connecting it to 0.45v with a voltage divider created with
a 10K and a 1K resistor. Or, maybe just connect it to ground.
You're doing all this in a simulator anyway. Maybe it will
accept ground as a "correct" Vee voltage on the LCD.
(Read the spec on the LCD for the simulator).
meereck
PostPosted: Wed Sep 10, 2008 3:47 pm     Reply with quote
why is RA4 connected to ground on the left side of the scheme?
The external pull-up doesnt work because there is ground all the time
Salenko
PostPosted: Thu Sep 11, 2008 5:41 am     Reply with quote
oooh, you're right !! Embarassed
well now, it running , thank you !! Wink
Salenko
PostPosted: Thu Sep 11, 2008 5:43 am     Reply with quote
www.brokerscreen.com/manufacture/HITACH/pn/LM016L.htm
thank you.
meereck
PostPosted: Thu Sep 11, 2008 3:35 pm     Reply with quote
glad that it works now.
regards
