RS232 problem
attabros
RS232 problem
PostPosted: Thu Sep 11, 2008 4:47 am     Reply with quote
Hi
I m tring to send data from controller to PC using PIC16F877A
& MAX232 firt i try just by sending "hello world" to PC using hyper
terminal,
I made the following code but dit does not work.
#include <16F877A.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES PUT                      //Power Up Timer
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // TODO: USER CODE!!
while (TRUE)
     printf("Hello World: \r\n");
is the code correct if not what will be the other possibilities to make it work
i have checked the hardware connections
i connect PIN 25 (TX) of controller to PIN 11 of MAX, PIN26 (RX) of
controller to PIN 12 of MAX on the other side on RS232 connector PIN 2 to 14 of MAX & PIN 3 to 13 of MAX & PIUN 5 ground.
RLScott
Re: RS232 problem
PostPosted: Thu Sep 11, 2008 5:35 am     Reply with quote
What do you see on pin RC7 when you look at it with a scope?
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
MicroManiac
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Sep 11, 2008 6:34 am     Reply with quote
What clock are you using???
i noticed that you are using an XT clock which should be less then 4Mhz
but in the code you are using #use delay(clock=20000000)
This will not work if you are using XT clock
Try it and let me know
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Albert Einstein
drh
PostPosted: Thu Sep 11, 2008 8:19 am     Reply with quote
Change this:
to this:
#FUSES HS
and try again.
David
attabros
PostPosted: Thu Sep 11, 2008 10:27 pm     Reply with quote
#fuses HS
it works THANKS
