But the CCS Compiler changes sign and exponent. (The sign is on position 23 and the exponent goes from bit 24 to 31).
Why is that so or I am wrong?
SherpaDoug
Posted: Wed Sep 10, 2008 6:27 am
I believe CCS still uses a format Microchip came up with before the IEEE came up with theirs. It is a choice between industry compatibility and backward compatibility. _________________ The search for better is endless. Instead simply find very good and get the job done.
wewa
Posted: Wed Sep 10, 2008 7:47 am
Oh ok.
I had only some problems on communication with VB.
Posted: Wed Sep 10, 2008 10:02 am
It is also fractionally easier to write using the PIC instructions. You get about 5% faster performance using this layout, and a PIC, than with the IEEE layout and the PIC. This changes with the latest DSPICs, and CCS switches to using IEEE format on these. I wrote my own assembler PIC libraries for the earliest 16 chips, and it saved a noticeable amount of time to go with this layout.
Sending to VB shouldn't be a problem. There are PIC libraries for doing the conversion included with the compiler now, and in the past several people have also posted versions (I have posted VB versions several years ago).
