ULN2803 with the pic 16f877
help me
PostPosted: Tue Sep 09, 2008 1:05 am     Reply with quote
hello i need some help.
I am still writing on the source code to conect the stepper motor and ULN2803 with the pic 16f877.
I try to show a motor rotate forward , backward , left , right and stop with five swicth
The following is my code. Could you tell me where is the problem?
this code
#define _PIC16F877_ // Use PIC16F877 device
#ifdef _PIC16F877_
#if defined(__PCM__)
#include <16F877.h>
#define TxD PIN_C6 // Define Transmitted Data
#define RxD PIN_C7 // Define Received Data
#define CLOCK_SP 20000000 // Clock Speed(Hz)
#include <input.c>
#BYTE port_b = 6
#define FOUR_PHASE TRUE
#ifdef FOUR_PHASE
BYTE const POSITIONS[4] = {0b0101,
                           0b1001,
                           0b1010,
                           0b0110};
#else
BYTE const POSITIONS[8] = {0b0101,
                           0b0001,
                           0b1001,
                           0b1000,
                           0b1010,
                           0b0010,
                           0b0110,
                           0b0100};
void main ()
    trisb =$00
    trisa =$ff
    adcon1 = 7
    lamp       var portb
    sw1        var portc.0
    sw2        var portc.1
    sw3        var portc.2
    sw4        var portc.3
    sw5        var portc.4
    lamp=0
     if(!sw1) then
         gosub speed1
         pause 50
     endif
     if(!sw2) then
        gosub speed2
        pause 50
     endif
    pause 10
 wend
end
speed1:
 lamp =$08
 pause 200
  while(sw2)
     lamp = lamp >> 1
     if lamp = $00 then lamp = $08
     pause 200
  wend
return
speed2:
 lamp =$01
 pause 200
 while(sw1)
     lamp = lamp << 1
     if lamp = $10 then lamp = $01
     pause 200
 wend
return
PostPosted: Tue Sep 09, 2008 1:37 am     Reply with quote
You are using the wrong programming language. The CCS compiler expects C, not BASIC.
