problem in sending hello world to hyperterminal
simpsonss
PostPosted: Mon Sep 08, 2008 4:03 am     Reply with quote
hi all,
i'm now trying to send "hello world" from my 16f877a through max232 to my hyperterminal. before that i'm trying the coding in asm and picBasic. but i still fail to send anything to my hyperterminal. Does anyone here can help me on this by using CCS? i need the simple coding way to make it works so that i know whether is my hardware problem or my coding problem.
thanks.
my connection is as below.
DB9 RS232 16f877a
pin2 (RxD) ------ T2out
T2in ----------------- Tx/ RB6
pin3 (TxD) ------ R2in
R2out ---------------- Rx/ RB7
PostPosted: Mon Sep 08, 2008 4:44 am     Reply with quote
First, keep your problems in one thread. Oherwise it results in loads on uneccessary thread titles all dealing with one thing...
You don't give the pin numbers you have used on the MAX232. You need:
DB9 Pin 2 (RXD) to MAX232 pin 7
MAX 232 pin 10 to PIC pin 25
DB9 pin 3 (TXD) to MAX232 pin 8
MAX232 pin 9 to PIC pin 26
MAX232 pin 16 to 5v
MAX232 pin 15 to 0v
5v to _all_ PIC Vdd connections
0v to all the PIC Vss connections
Capacitor from Vdd to Vss close to the PIC. 0.1uF ceramic.
Capacitor from Vdd to Vss close to the MAX232. 47uF.
Capacitor between pins 4, and 5 of the MAX232 (depends on what version MAX232 you have - say 1uF). Same between pins 1 and 3. One from pin 6 to 0v. Another from pin 2 to 5v (or 0v, but then needs at least a 20v voltage rating).
DB9 pin 5 to 0v.
Then the PIC needs a resistor from pin 1 to 5v (say 4K7R).
Crystal between pins 13, and pins 14 on the PIC. Say 8Mhz or something around here (4 to perhaps 20MHz). Capacitor from each of these pins to 0v, try 27pF.
5v supply to the board.
Then the most basic code:
#INCLUDE   <16F877A.H>
#FUSES      HS,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP,NOCPD,WRT
//Change 'HS' here to 'XT' if using a 4MHz crystal
#USE DELAY(CLOCK=8000000)
//Change number here to match crystal used.
void main() {
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   //Pause to allow the Maxim charge pump to get going
   putc("Hello World\n\r");
   while (TRUE) ;
Now, this is as basic as it is possible to go. If you can't get even this to work, you need to find somebody to actually show you what to do. We can't get much simpler...
Douglas Kennedy
PostPosted: Mon Sep 08, 2008 1:17 pm     Reply with quote
There are many ways to mess up what appears to be the simple task of sending a message via RS232 to a PC. Ttelmah advice is strong in insisting that the PIC side be kept as simple as possible. The choice of hyperterminal on the PC side often contributes to confusion. Hyperterm has many surprises ( free features) for the inexperienced to hang up on. Use CCS's SIOW or terraterm for clearer results if you can.
SherpaDoug
PostPosted: Mon Sep 08, 2008 4:32 pm     Reply with quote
I would slightly modify the code ttelmah supplied:
void main() {
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_vref(FALSE);
   while (TRUE) {
This way it keeps sending while you play with the PC or wires.
PostPosted: Tue Sep 09, 2008 12:13 am     Reply with quote
hi all,
Thanks for the reply. When I try it by using a 4Mhz OSC it works. But when I change the OSC to 20Mhz it doesnt work. When I change the value of the OSC to 20 Mhz I also changed the code as below.
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
But it seems like not working. I can't get anything from the hyperterminal.
thanks.
PostPosted: Tue Sep 09, 2008 2:41 am     Reply with quote
You say 'OSC'. Presumably you mean _crystal_?. A crystal, is not an oscillator, without other parts. It is an important distinction, since you can have complete 'oscillators' in a package, and these need different wiring, and fuses.
Now, what is the specified loading capacitance for your 20MHz crystal?. Do you have any data on it at all?. Is it series of parallel resonant?. What is it's ESR?. Shunt capacitance?. How is the board laid out?. Getting the oscillator to run at all, is harder at higher frequencies. My 'guess' is that you are working on some sort of breadboard, and the stray capacitances are so high, that the 20MHz part just won't oscillate. It may be possible to get it to oscillate, but doing so, needs _data_.
PostPosted: Tue Sep 09, 2008 7:30 pm     Reply with quote
Hi Ttelmah,
Sorry for my wording. I'm using a 20Mhz XTAL. It just a very simple two legs XTAL. Without datasheet. I connect 1 leg to Pin13 of PIC and another leg to Pin14 of PIC. And then both legs connect to each 22pF no polarity capacitor, and both legs of cap to ground.
What should I do to let the XTAL run ?
Thank you.
