Problem with fast CRC16
piripic
PostPosted: Mon Sep 08, 2008 2:14 am     Reply with quote
I am testing the fast CRC16 algorithm, the two functions never return the same result also initializing the variable MyCRC to 0xFFFF, where I mistake ?
Here my test code:
#include <18F24K20.h>
#device adc=8
#FUSES NOWDT, HS, NOPROTECT, NOBROWNOUT, NOPUT, NOCPD, STVREN
#FUSES NODEBUG, NOLVP, NOWRT, NOWRTD, IESO, FCMEN, NOPBADEN, WRTC
#FUSES NOWRTB, NOEBTR, NOEBTRB, NOCPB, LPT1OSC, MCLR
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
unsigned int16 FSR0;
#locate FSR0 = 0x0FE9
unsigned int8 POSTINC0;
#locate POSTINC0 = 0x0FEE
#define MYDIM 2
int8 MyArray[MYDIM];  // Global Array
int16 crc_1021(int16 old_crc, int8 data)
  int16 crc;
  int16 x;
  x = make8(old_crc,1) ^ data;  //x = ((old_crc>>8) ^ data) & 0xff;
  x ^= x>>4;
  crc = (old_crc << 8) ^ (x << 12) ^ (x <<5) ^ x;
  crc &= 0xffff;
  return crc;
// Calculate the CRC16 value of a specified buffer.
// A very fast CRC-16 routine based on the CCITT polynome 0x1021.
// This implementation is very small and fast. Using some specific features of
// the polynome the resulting code is even faster than table driven algorithms.
// Original Code: Ashley Roll       www.digitalnemesis.com
// Optimisations: Scott Dattalo     www.dattalo.com
int16 Calc_Crc16(int8 *Buffer, int16 Len) // Note: save 5 instructions by
{                                         // changing 'int16 Len' to 'int8 Len'.
  int8 Index;
  union
    int8  uByte[2];
    int16 uWord;
  } CRC16;
  CRC16.uWord = 0xFFFF;     // Initialise CRC to 0xFFFF
  FSR0 = Buffer;            // Copy Buffer address to pointer register FSR0
  do
    #ASM
    movf  POSTINC0,w        // load w with next databyte
    xorwf CRC16.uByte[0],w  // (a^x):(b^y)
    movwf Index             //
    andlw 0xf0              // W = (a^x):0
    swapf Index,f           // Index = (b^y):(a^x)
    xorwf Index,f           // Index = (a^b^x^y):(a^x) = i2:i1
                            // High byte
    movf  Index,W
    andlw 0xf0
    xorwf CRC16.uByte[1],W
    movwf CRC16.uByte[0]
    rlcf  Index,W           // use rlf for PIC16
    xorwf CRC16.uByte[0],f
    andlw 0xe0
    swapf Index,F
    xorwf Index,W
    movwf CRC16.uByte[1]
    #ENDASM
  } while (--Len);
  return CRC16.uWord;
// **********  M A I N   P r o g . ***********
   int8 i;
   int16 MyCRC=0;
   for(i=0 ; i<MYDIM ; i++) {
      MyArray[i] = i+1;   // fill the array
//----calc CRC16 By C function-----------------
      MyCRC = crc_1021(MyCRC,MyArray[i]);
   printf("C CRC16 value is %Lu\n\r", MyCRC);     // Send the result (C function)
//----calc CRC16 by assembly function----------
   MyCRC = Calc_Crc16(&MyArray[0],MYDIM);
   printf("ASM CRC16 value is %Lu\n\r", MyCRC);   // Send the result (assembly function)
   while(1) ;
Any ideas ? thanks
Claudio
piripic
resolved
PostPosted: Mon Sep 08, 2008 6:06 am     Reply with quote
Now is ok; this is the working code:
#device adc=8
#define MYDIM 64
  int16 crc;
  int16 x;
  x ^= x>>4;
  crc &= 0xffff;
  return crc;
  int8 Index;
  union
    int8  uByte[2];
    int16 uWord;
  } CRC16;
  do
    #ASM
    xorwf CRC16.uByte[1],w  // (a^x):(b^y)
    movwf Index             //
                            // High byte
    movf  Index,W
    andlw 0xf0
    xorwf CRC16.uByte[0],W
    xorwf CRC16.uByte[1],f
    andlw 0xe0
    swapf Index,F
    xorwf Index,W
    #ENDASM
  } while (--Len);
  return CRC16.uWord;
   int8 i;
   int16 MyCRC;
   MyCRC = 0xFFFF;
   while(1) ;
I have inverted the CRC16.uByte index value
Claudio
