chriss2000 Guest
Timer0 Problems |
Posted: Thu Jan 23, 2003 1:35 pm |
<font face="Courier New" size=-1>This is a code for manchester decoding !
can anyone tell me why the syntax
if(count>abtast)
doesn't work ??
There i want to ask if the counter value is greater than my scanvalue !?!
if(count>10) for instance works, why can't i put there a integer ???
#include <16f876.h>
#Device ICD=TRUE
int newbit=0,flag=0,i=0,a=0;
long count=0,code=0,zero=0,abtast=10;
#int_ext
isr()
flag=1;
set_tris_A(0xFF);
set_tris_B(0xFF);
set_tris_C(0x00);
setup_timer_0(RTCC_DIV_128|RTCC_INTERNAL);
//Timer 0 Setup --> Interner RTCC Teilung durch 128--> zählt mit 7.8125kHz//Teilung: beim Zählstand 1 sind 128us vergangen;in 1ms zählt er bis 7.8125
enable_interrupts(int_ext);
ext_int_edge(H_TO_L);
enable_interrupts(global);
while(True)
while(flag == 1)
disable_interrupts(global);
if(i<14) //14 mal abtasten
set_timer0(10);
count=get_timer0();
if(count>=abtast)
newbit=input(Pin_A0); code=zero|newbit; code=code<<1; abtast=abtast+14; //abtast um 14 erhöhen [1,792ms]
output_c(0xFF);
i++;
flag=0; abtast=10;
//Timerwert 10 entspricht 1,3ms, wodurch das Abtasten des neuen Signals im 3/4ten Bit synchronisiert wird
code=0;
newbit=0;
i=0;
delay_ms(80);
___________________________
Original Post ID: 10947 |
Re: Timer0 Problems |
Posted: Thu Jan 23, 2003 4:09 pm |
<font face="Courier New" size=-1>:=This is a code for manchester decoding !
:=can anyone tell me why the syntax
:=if(count>abtast)
:=doesn't work ??
:=There i want to ask if the counter value is greater than my scanvalue !?!
:=if(count>10) for instance works, why can't i put there a integer ???
If something doesn't work, and you're not sure whether it's
a compiler bug, or if it's your problem, then make a small
test program. Here's an example:
<PRE>
#include "c:\program files\picc\devices\16F877.h"
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=8000000)
<BR>
char i;
long count;
long abtast;
<BR>
count = 10;
<BR>
for(i = 5; i < 15; i++)
abtast = i;
if(count >= abtast)
printf("abtast = \%ld Count is >= abtast\n\r", abtast);
printf("abtast = \%ld Count is < abtast\n\r", abtast);
</PRE>
This program tests the problem that you complained about.
Here is the output on the terminal window:
<PRE>
abtast = 5 Count is >= abtast
abtast = 6 Count is >= abtast
abtast = 7 Count is >= abtast
abtast = 8 Count is >= abtast
abtast = 9 Count is >= abtast
abtast = 10 Count is >= abtast
abtast = 11 Count is < abtast.
abtast = 12 Count is < abtast.
abtast = 13 Count is < abtast.
abtast = 14 Count is < abtast.
That output looks good. It's what I would expect.
I tested this with PCM vs. 3.136.
Whenever you have a problem where you don't understand
something, always make a short test program. That's what
I do. I've done it hundreds of times.
With regard to your main program: You still have some
problems in your design. I notice that you disable all
interrupts with "disable_interrupts(global)", but then
you never turn them back on. At the end of your code
you have "enable_interrupts(int_ext)". That line won't
do anything, because you still have GLOBAL interrupts
turned off. I think someone told you this before.</font>
Original Post ID: 10950 |
Hans Wedemeyer Guest
Posted: Thu Jan 23, 2003 4:49 pm |
:=With regard to your main program: You still have some
:=problems in your design. I notice that you disable all
:=interrupts with "disable_interrupts(global)", but then
:=you never turn them back on. At the end of your code
:=you have "enable_interrupts(int_ext)". That line won't
:=do anything, because you still have GLOBAL interrupts
:=turned off. I think someone told you this before.
Yes I did, once on this board and once by private email.
I guess he/she is never going to learn or take advice.
It's strange, he/she comes here and we spend time trying to help and it's ignored...
I simply do not understand the attitude !
Original Post ID: 10953 |
chriss2000 Guest
Posted: Fri Jan 24, 2003 2:13 pm |
hey pcm programmer, you haven't understood my problem, i want to ask if a timervalue wich i get trough "get_timer0()" is greater or smaller than an integer and this doesn't work.
And a few words to hans wedemeyer, i don't want your statements in my posts, this is really childish what you make, stop it.
You are not very helpfull. I just want some help and i can't make anything against people who missundersatand my questions !!
Original Post ID: 10974 |
chriss2000 Guest
Posted: Fri Jan 24, 2003 3:41 pm |
Original Post ID: 10977 |
Posted: Fri Jan 24, 2003 3:53 pm |
Well if you take the advice you ask for instead of ignoring it you will get your program to work.
Remember this board is voluntary and when you contacted me at my private address you did not even have the common decency to say thank you for the time I spent sending you a reply.
Since the you have posted code that several people have commented upon and you ignore the advice....
It is truly strange why you even bother to ask for help.
Original Post ID: 10978 |
