USB program wont move forward
madtoilet
PostPosted: Thu Jul 31, 2008 12:10 pm     Reply with quote
hi, i'm having issues with my USB CDC code. I'm using the example but when combined with my code the program wont move forward unless i hit the keyboard.
the code is as follows:
#define __USB_PIC_PERIF__ 1
#if !defined(__PCH__)
 #error USB CDC Library requires PIC18
#endif
 #DEFINE LED1  PIN_A5
 #include <18F4550.h>
 #include <string.h>
 #fuses XT,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL1,CPUDIV1,VREGEN
#use rs232(baud=4800,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=GSM,bits=8,ERRORS)
#include <usb_cdc.h>
#define LED2 PIN_B4
#define LED3 PIN_B5
#DEFINE BUTTON PIN_A4
#define LED_ON output_low
#define LED_OFF output_high
#byte RCREG = 0x1A
#define BUFFER_SIZE 80
char inStr[BUFFER_SIZE];
char char_rcvd;
char done = 1;
int set_flag = 0;
//int cursor=0x80;
int i=0;
int sentence= 0;
void out_LCD(int i);
void int_LCD(void);
void cursor_position(int position);
void out_LCD_string(char *string);
void clear(void);
char intro[]="Altus Fortis inc.";
char intro2[]="KabTrak Beta";
char intro3[]="** Ver. 1.05 **";
char initial[]="Initializing...";
char ready[]="Ready";
void altus_fortis_init(void);
//char number[11]="5 ";
//byte num[] ="5104682725";
char temp[70] = "  ";
#int_rda
void serial_isr() {
char_rcvd = fgetc(GSM);
if( char_rcvd == '$'){
      set_flag = 1;
      if(set_flag ==1 && i <= 62){
      inStr[i]= char_rcvd;
      i++;
void usb_debug_task(void) {
   static int8 last_connected;
   static int8 last_enumerated;
   int8 new_connected;
   int8 new_enumerated;
   static int8 last_cdc;
   int8 new_cdc;
   new_connected=usb_attached();
   new_enumerated=usb_enumerated();
   new_cdc=usb_cdc_connected();
   if (new_enumerated)
      LED_ON(LED1);
      LED_OFF(LED1);
   if (new_cdc)
      LED_ON(LED2);
     LED_OFF(LED2);
   if (usb_cdc_carrier.dte_present)
         LED_ON(LED3);
      LED_OFF(LED3);
   if (new_connected && !last_connected)
      printf("USB connected, waiting for enumaration...\r\n\n");
   if (!new_connected && last_connected)
      printf("USB disconnected, waiting for connection...\r\n\n");
   if (new_enumerated && !last_enumerated)
      printf("USB enumerated by PC/HOST\r\n\n");
   if (!new_enumerated && last_enumerated)
      printf("USB unenumerated by PC/HOST, waiting for enumeration...\r\n\n");
   if (new_cdc && !last_cdc) {
      printf("Serial program initiated on USB<->UART COM Port\r\n\n");
      printf(usb_cdc_putc, "\r\n\nCCS CDC (Virtual RS232) Example\r\n\n");
   last_connected=new_connected;
   last_enumerated=new_enumerated;
   last_cdc=new_cdc;
void main(void) {
char c;
int gsm_set = 0;
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   enable_interrupts(global);
   disable_interrupts(int_rda);
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
output_b(0x00);
output_low(PIN_C2);
output_high(PIN_C2);
delay_ms(2000);
output_low(PIN_C2);
output_low(PIN_C2);
int_lcd();
delay_ms(400);
altus_fortis_init();
delay_ms(4000);
clear();
out_lcd_string(initial);
delay_ms(30000);
clear();
cursor_position(0x94);
out_lcd_string(ready);
output_b(0x00);
cursor_position(0x80);
   LED_OFF(LED1);
   LED_OFF(LED2);
   LED_OFF(LED3);
   while (TRUE) {
  // #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
      usb_task();
      usb_debug_task();
      if (kbhit()) {
         c=getc();
         if (c=='\n') {usb_cdc_putc('\r'); usb_cdc_putc('\n');}
         if (c=='\r') {usb_cdc_putc('\r'); usb_cdc_putc('\n');}
         else {usb_cdc_putc(c);}
         output_b(0x02);
      if (usb_cdc_kbhit()) {
         c=usb_cdc_getc();
         if (c=='\n') {putc('\r'); putc('\n');}
         if (c=='\r') {putc('\r'); putc('\n');}
         else {putc(c);}
         output_b(0x01);
                          if(gsm_set == 0){
                                 output_b(0xff);
                                 fprintf(GSM, "AT+CMGF=1\r\n");
                                 //fprintf(GSM, "\r\n");
                                 delay_ms(3500);
                                 //delay_ms(500);
                                 fprintf(GSM, "AT+CMGR=3\r\n");
                                 delay_ms(1);
                                 enable_interrupts(int_rda);
                                 gsm_set = 1;
                           if(i >= 62){
                                 clear();
                                 set_flag = 0;
                                 gsm_set = 0;
                                 inStr[i]=0;
                                 out_lcd_string(inStr);
                                 printf(usb_cdc_putc, "\r\n %s in if 2\r\n", inStr);
                                 sentence = 0;
                                 i=0;
            printf(usb_cdc_putc,"\r\n go back around \r\n");
the program does what i need as long as i keep hitting the keyboard. I'm trying to get it to move forward without hitting the keyboard. I'm wondering if it's my interrupt that is stopping the program. I'm really stumped i've gone all around trying to keep getting it to work. Any help would be appreciated.
PostPosted: Thu Jul 31, 2008 7:55 pm     Reply with quote
Not sure if this is your problem but the getc() in your main loop will do a blocking wait if no data is available.
The kbhit() should prevent this blocking behaviour but there is a problem with int_rda() reading the data from the same port in an interrupt.
madtoilet
PostPosted: Fri Aug 01, 2008 9:23 am     Reply with quote
i'll try to remove the getc(). However, if the problem is with reading from the same port, how do i go around this? would a serial->usb solution not work in my case then?
madtoilet
PostPosted: Thu Sep 04, 2008 2:18 pm     Reply with quote
i was on a break for a while.
if there is a problem with my int_rda picking up from the same port, should i configure my serial port for my USB to another port?
madtoilet
PostPosted: Thu Sep 04, 2008 2:22 pm     Reply with quote
I'm also getting USB re-entrancy warnings. I'm not entirely sure how to get rid of those. When i do get rid of them, the program wont work. I may be getting rid of it wrongly
FvM
PostPosted: Thu Sep 04, 2008 4:46 pm     Reply with quote
Your intentions with the RS232 input are appearing mysterious.
madtoilet
PostPosted: Fri Sep 05, 2008 1:06 pm     Reply with quote
oh i'm sorry. I'm using the rs232 to receive information from a GSM unit. whenever i send out a command, the rs232 will receive serial data from the GSM.
FvM
PostPosted: Fri Sep 05, 2008 3:24 pm     Reply with quote
Yes, I see this so far. But the handling is strange to my opinion. Enabling the interrupt reception while the background kbhit() action is still in effect, as far as I understand. Creates a kind of race condition with unpredictable behaviour, I fear.
madtoilet
PostPosted: Mon Sep 08, 2008 2:38 pm     Reply with quote
yes! it is a strange way of handling, i re did the whole code and fixed it. The whole approach that i was using was very wrong. I found a much simpler way to do it that actually makes sense. Thanks for all the help!
