Is there a way to establish the priority in the PIC18F's?
Posted: Thu Sep 04, 2008 11:32 am
hi everybody...
I want know if there is a way to declare the priority of an interrupt in the PIC 18F's.
As far as i know the directive #priority only tells the order that the interrupts will be implemented. So, if an int_ext1 occurs while the pic process the int_ext2 nothing will happen, but I think the PIC18F has two types of priorities, so in the example above I could stop the execution of the int_ext2 and run the int_ext1 (if I put them in the right interrupt vectors)
thanks!!
dyeatman
Posted: Thu Sep 04, 2008 1:11 pm
If you search this forum using the words "high" and "priority" you will find a great deal on the subject including examples.
