Question about SPI_SS_DISABLED
Carlos Eguti
PostPosted: Thu Sep 04, 2008 7:27 am     Reply with quote
Hi everybody !
I have some question about SPI...
When I'm using SPI communication between two 16F877, can I use the pin A5 from MASTER for I\O ? This pin on SLAVE is the SPI_SS Enable line, but in MASTER device is not necessary, correct ? The constant SPI_SS_DISABLED have effect on MASTER device??
RLScott
Re: Question about SPI_SS_DISABLED
PostPosted: Thu Sep 04, 2008 9:37 am     Reply with quote
Carlos Eguti wrote:
Hi everybody !
No, the SPI_SS_DISABLED only applies to slave devices. There is no automatic SS function in master mode. You can define any I/O pin you want as the SS output from the master. It does not have to be pin A5.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
Carlos Eguti
PostPosted: Tue Sep 09, 2008 1:47 pm     Reply with quote
OK
Thanks a lot!
