PIC18F452 memory storing!
kkaitlin
PostPosted: Wed Sep 03, 2008 7:11 pm     Reply with quote
I badly need help in this!
I'm currently doing a project and it involves the storing of numbers.
I need the program to read the number when the power is on and store the numbers when the power is off.
I have no idea what are the codes for it.
Please help. Crying or Very sad
PostPosted: Wed Sep 03, 2008 7:29 pm     Reply with quote
Look at these routines which get numbers from a terminal program:
get_int()
get_int32()
get_float()
The routines are in this file:
c:\program files\picc\drivers\input.c
Then look at the write_eeprom() and read_eeprom() functions in
the CCS manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look at this FAQ article which explains how to store a floating point
number in eeprom:
http://www.ccsinfo.com/faq.php?page=write_eeprom_not_byte
kkaitlin
PostPosted: Wed Sep 03, 2008 7:46 pm     Reply with quote
Then what about to store?
Will it store the numbers?
'Cos I have a reset function too.
Actually this works like a safebox.
Whereby it can read, store, delete, rewrite numbers.
PostPosted: Wed Sep 03, 2008 8:23 pm     Reply with quote
Look at the write_eeprom() function in the CCS manual.
Look at the FAQ article that you were given a link to.
