Joined: 22 Jan 2008 Posts: 4 Location: Canal Flats BC
have an problem with unsigned integer division
Posted: Fri Aug 29, 2008 10:54 pm
I have an issue with unsigned integer division, using a 16F88, job is a frequency generator.
problems with the result in half_period
frequency is a value from 1-1000, determined from a scan of bcd switches.
it works fine so long as freq is <256, then it messes up.
unsigned int16 freq;
unsigned int32 half_period
half_period = 500000/freq;
help!
Posted: Fri Aug 29, 2008 11:50 pm
Show the printf statement that you're using to display the result.
Post your compiler version.
mthornton
Posted: Tue Sep 02, 2008 7:44 am
Compiler version : PCM 3.241
didn't use a printf statements, as the output is the signal out
I found the problem, which was my misunderstanding of the type conversion in the routine used to create the "frequency" variable (unsigned 16 bit) from 3 - 8-bit bcd switches. Won't get bitten by this again.
