rs232
rvdbogae
rs232
PostPosted: Tue Apr 16, 2002 3:40 pm     Reply with quote
Hi
I am experimenting with rs232 communication.
I' ve send characters to a computer, this is easy.
Now I like to read characters from this computer(a value) into my pic. (16F877).
Is it possible with a terminal programm????
Are there free terminal programms avaliable
I'm looking for an example, how to read a value from a rs232 connection (PC) into my pic.
Thanks a lot,
___________________________
Original Post ID: 3824
Jay
Re: rs232
PostPosted: Wed Apr 17, 2002 1:55 am     Reply with quote
Try HyperTerminal (standard in most Windows versions)
Regards,
:=Hi
:=I am experimenting with rs232 communication.
:=I' ve send characters to a computer, this is easy.
:=Now I like to read characters from this computer(a value) into my pic. (16F877).
:=Is it possible with a terminal programm????
:=Are there free terminal programms avaliable
:=I'm looking for an example, how to read a value from a rs232 connection (PC) into my pic.
:=Thanks a lot,
Original Post ID: 3828
Jay
Re: rs232
PostPosted: Wed Apr 17, 2002 1:56 am     Reply with quote
Try HyperTerminal (standard in most windows versions)
Regards,
Jay
:=Hi
:=Thanks a lot,
Original Post ID: 3830
rvdbogae
Re: rs232 whats wrong
PostPosted: Wed Apr 17, 2002 5:19 am     Reply with quote
This rs232 example does not work at all,
what is wrong??
#include <16f877.h>
#fuses HS,NOWDT,NOPROTECT
main() {
printf("start");
putc( getc()+1);
Original Post ID: 3832
Sherpa Doug
PostPosted: Wed Apr 17, 2002 7:59 am     Reply with quote
Are you using a software UART? I am not familliar with the 16f877). If so getc() will return what is sees in the input pin when it is called. This will probably be $00 or $ff depending on how the serial line is setup. Getc() does not wait for the next character to come along. You need to make sure the line is at Stop bit level, then wait for it to begin a Start bit, then call getc(). Look at the kbhit() function.
:=This rs232 example does not work at all,
:=what is wrong??
:=Thanks
:=#include <16f877.h>
:=#fuses HS,NOWDT,NOPROTECT
:=#use delay(clock=20000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
:=main() {
:= printf("start");
:= while(TRUE)
:= putc( getc()+1);
Original Post ID: 3836
