Function Prototype causes "Expecting an identifier"
/dev/human
PostPosted: Mon Sep 01, 2008 2:38 am     Reply with quote
Hi Folks,
I can't figure out what's causing the "Expecting an identifier" error in my code. Using MS Visual C++ compiler my world was looking fine.
There is a prototype of the function in the header file
char LCDprintf (unsigned char, char [], float);
unsigned char LCD_RW_IO (unsigned char, unsigned char, unsigned char);
void LCD_Init ();
And the the module function code is this
char LCDprintf (unsigned char Line, char String [], float Value) {
   char LCDstring[MaxLCDcolumn+4];                        // Make sure string is long enough including some formating
   int i;
   char Error = 0;
   strncpy (LCDstring, String, sizeof (LCDstring));         // Truncate string to max columns of LCDstring
   LCDstring [sizeof (LCDstring) - 1] = '\0';               // Add string terminator at the end
   sprintf (LCDstring, LCDstring, Value);                  // Insert the "value" according to format information
   LCDstring [MaxLCDcolumn] = '\0';                     // Make sure to have number of characters fitting on the LCD row
   for (i = strlen (LCDstring); i < MaxLCDcolumn; i++) {      // Fill up if necessary
      LCDstring [i] = ' ';
#if MaxLCDcolumn == 16 & MaxLCDrow == 3 // Next lines only for 16 x 3 line display
   if (Line >= 1 && Line <= 3) {                        // Check for valid row number
      LCD_RW_IO (((Line - 1) * 16) | 0x80, Write, Command);   // Set display curser to line
#ifdef PC_Debug
      printf ("Data sent to LCD: _");
#endif
      for (i = 0; i < MaxLCDcolumn; i++) {               // Write charaters of one line to display
         LCD_RW_IO (LCDstring [i], Write, Data);
#ifdef PC_Debug
         printf ("%c", LCDstring [i]);
#endif
#ifdef PC_Debug
   printf ("_\n");
#endif
   else {
      Error = Illegal_Line;
#endif
   return Error;
Thanks in advance for help
PostPosted: Mon Sep 01, 2008 3:21 am     Reply with quote
The prototypes need to have the variable names as well. So the prototype for the first function, becomes:
char LCDprintf (unsigned char Line, char String [], float Value);
This is a difference between the original C, and latter implementations. Originally 'C', didn't support prototypes at all, but allowed them in the form that CCS implements. Latter, ones without variable names, were added to ANSI C, and this has continued since.
/dev/human
Solved
PostPosted: Mon Sep 01, 2008 3:29 am     Reply with quote
Thanks, I wasn't aware of this. It's working fine now (at this place). although I'm wondering, why it's happening only with this prototype. The other ones are compiled neatly.
