Creating pointers to constants in PCD
FvM
PostPosted: Fri Aug 29, 2008 3:50 am     Reply with quote
the PCD manual contains the below example:
const char *cptr;
cptr = string;
But the compiler doesn't accept const char as a pointer definition, it requests a = for a constant definition.
Is the manual text written by mistake or is the compiler implementation yet incomplete?
Regards,
Frank
mr7
Found the same
PostPosted: Fri Aug 29, 2008 12:03 pm     Reply with quote
Running version 4.068 I get the same result.
const char *cptr;
cptr = string;
Expecting an =
Expecting a (
Expecting a (
Expecting a declaration
PostPosted: Fri Aug 29, 2008 1:49 pm     Reply with quote
Try ROM instead.
On the other (non PCD) compilers, pointers to constants will work, but _only_ in some compiler modes. ROM used in the same way as const, functions much better. It may work for PCD as well.
FvM
PostPosted: Fri Aug 29, 2008 4:39 pm     Reply with quote
Thanks, apparently, PCD isn't understanding the rom storage class modifier, at least not as synonymous for flash access.
