Procedure of bootload
joe2008
PostPosted: Thu Aug 28, 2008 8:26 pm     Reply with quote
I has something about the procedure of bootload, but don't sure.
1)Firstly, i need to build my bootloader, using ex_bootloader.c, bootloader.c, bootloader.h in CCS folder. Update the real_load_program in bootloader.c to fit for bootload through I2C communication. Now make a bootload.exe, bootload area mostly in 0x0000-0x0400.
2)inport bootload.exe and program my PIC18F4520 with ICD2.
3)Make another project file, build my application hex file as below (above 0x500):
#define _bootload
#ifdef _bootload
#define LOADER_END 0x7FF
#define LOADER_SIZE 0x6FF
#build(reset=LOADER_END+1, interrupt=LOADER_END+9)
#org 0, LOADER_END {}
4) Power up MCU and provide power for SCL&SDA line, run my VB program sending my application hex file through I2C, MCU self-program.
It that procedure OK? Need your advice. Thanks.
PostPosted: Thu Aug 28, 2008 11:41 pm     Reply with quote
it is working exactly as you described (also according to the ex_bootload.c and ex_bootloader.c and bootload.h examples). The restriction is to use no interrupts in the bootloader, cause the global interrupt is directly forwarded to application. This should be O.K. in most cases.
To protect the bootloader, it should no allow to overwrite it's own program space, whatever is requested in the received image file.
As a another comment, I prefer not to simply import the *.hex or *.cof in MPLAB, but to setup a respective workspace and project to support debugging of the application by ICD2.
RobertoP
PostPosted: Tue Sep 02, 2008 3:52 am     Reply with quote
I'm trying to compile the bootloader and the application in a single step,
including the bootloader code inside of my application, but I want that remains two separate programs.
I tried several changes to bootldr.c, bootldr.h, ldr.c, but always I get errors about #org and #build directives.
Someone has already solved this problem ?
I need a sample or indications to make the compilation/link in a single step.
Thanks,
