RS232 error for multiple RS232 ports on one chip
Rainy
PostPosted: Thu Aug 28, 2008 1:20 pm     Reply with quote
Hello everyone,
I'm using PIC18F452 for my project. I have 1 hardware UART and 2 sw UARTS in one chip. I'm just wondering if I want to use the "error" option, how can I distinguish the error for different streams?
If I declare like this, I found that the latter one is the one taking effect, the first one seems to be overwriten by the latter one.
Thanks a lot for any help!
#use rs232(baud=9600,parity=N,xmit=PIN_B4,rcv=PIN_B2,stream=portA,bits=8, errors, timeout=RS232_TIMEOUT)
#use rs232(baud=9600,parity=N,xmit=PIN_B3,rcv=PIN_B1,stream=portB,bits=8, errors, timeout=RS232_TIMEOUT)
PostPosted: Thu Aug 28, 2008 1:24 pm     Reply with quote
The ERRORS parameter only works with the hardware UART.
The compiler ignores it for software UARTs.
Rainy
PostPosted: Thu Aug 28, 2008 1:29 pm     Reply with quote
Thanks for your reply. So is there any solution for a timeout on the S/W UART? Acutally in my test, seems it works for the latter UART, when I unplug the RS232 device from this port, it can get out. Yet for the first declared RS232 port, if I unplug the device, it just hung there.
PostPosted: Thu Aug 28, 2008 1:40 pm     Reply with quote
Now I see what you're talking about. My comment about ERRORS
referred to the ability to automatically clear a receiver overrun error.
You're referring to this feature of the #use rs232() library code:
TIMEOUT=X
To set the time getc() waits for a byte in
milliseconds. If no character comes in within
this time the RS232_ERRORS is set to 0 as
well as the return value form getc(). This works
for both UART and non-UART ports.
Rainy
PostPosted: Thu Aug 28, 2008 1:48 pm     Reply with quote
Yes you are right. That's what I'm trying to say. Sorry about the bad expression.
So any solution for that? Thanks for your prompt response!
Rainy
PostPosted: Thu Aug 28, 2008 1:52 pm     Reply with quote
I tried to use a loop like this
code
}  while (RS232_ERRORS);
but only works for one port.
Maybe I'll have to put my own timer there for timeout.
PostPosted: Thu Aug 28, 2008 2:19 pm     Reply with quote
CCS has an example code for the timed_getc() function here:
c:\program files\picc\examples\ex_tgetc.c
You would have to modify it to work with a particular stream.
Change the getc() to fgetc(), and specify the stream in the kbhit()
function. I notice the sample code uses a software delay loop.
That could cause a problem with a software UART. It adds an
delay between the detection of the start bit and the reception of
the other bits. It might reduce the reliability of the software
UART.
Rainy
PostPosted: Fri Aug 29, 2008 1:23 pm     Reply with quote
Thanks a lot, PCM programmer! I got it work following your advice.
