Structure
Structure
PostPosted: Wed Aug 27, 2008 12:55 pm     Reply with quote
What is wrong with the following code?
typedef struct Settings
int8 bw;
int8 sd;
int8 sr;
int8 fdma;
int8 fixnmap;
{ SettingsT;
I get unknown type error.
Ver. 4.071
pic 18f8722
PostPosted: Wed Aug 27, 2008 1:10 pm     Reply with quote
It's solvable by inspection.
I want to say this politely. This board is about using the CCS compiler.
It's not intended to teach C programming. The people on here want to
answer questions that are at a higher level than incorrect brace usage.
You need to take a course on C and get past the beginner stage.
