Struct problem
DonWare
Struct problem
PostPosted: Fri Jul 13, 2007 1:33 pm     Reply with quote
Hi, I'm having trouble defining a struct. The code below compiles OK but complains about subscript range errors if I increase the numbers to ~10 or more. I'm using a PIC16F877.
struct setup{
int8 pname[5];
int8 seq_cnt;
int8 sname[5];
int8 sdata[5];
}MyData[5];
I didn't do the math but is it really just purely an 'out of memory' problem ?
Also, hows does using a 'union' differ. I can't find much into on it within CCS.
Thanks. Don
PostPosted: Fri Jul 13, 2007 1:39 pm     Reply with quote
In a 16F877, the largest available block of user RAM within a single RAM
bank is 96 bytes. A structure must contained within one RAM bank.
It can't span two or more banks. That's the reason for the error message.
To remove this limitation, use an 18F PIC with the PCH compiler.
DonWare
PostPosted: Fri Jul 13, 2007 2:47 pm     Reply with quote
OK thanks. That example I gave only totaled 80 bytes (I think). But I'll keep it in mind.
Don
PostPosted: Fri Jul 13, 2007 3:03 pm     Reply with quote
Right, but you said the problem was not with the posted structure, but
rather with another one (not shown) that had the array size(s) increased
to 10. If you still have a problem, post the structure that is causing the
error.
ferdem
PostPosted: Wed Aug 27, 2008 5:01 am     Reply with quote
I have 18F4520 and I want to span banks to use large arrays. How can i do this in CCS? I have searched the word "RAM" in CCS C help and i have read almost all results but i couldnt find releated subject. Thanks
PostPosted: Wed Aug 27, 2008 10:19 am     Reply with quote
Just define the array.
On the 18 chips, the limit is the amount of RAM you have available.
On the original question, regarding the 'union', this is a way of making _two_ (or more) different 'types' of variable use the same memory area. So if (for instance), you create a union as:
union {
   int8 b[4];
   float f;
} val;
Then 'val.f' is a floating point variable, and val.b[0] to val.b[3] are four int8 variables _stored in the same area of memory_. You can then write a float into the area, and read it out as bytes, or vice versa.
