Plz help me with INTERNAL OSC
HTAluvBeBeo
PostPosted: Tue Aug 26, 2008 11:05 am     Reply with quote
Plz Help me to config 18f2525 to use Internal oscillator at 8MHz and 32MHz.
Here is my test code.
I tested with Proteus to simulate my program.
#include <18F2525.h>
 #fuses NOWDT, HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP
 #use delay(clock=8000000)
 {   setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_OFF);
 set_tris_a(0x00);
 output_A(0x00);
   output_high(PIN_A6);
   output_low(PIN_A7);
   output_high(PIN_A7);
   output_low(PIN_A6);
rnielsen
PostPosted: Tue Aug 26, 2008 12:17 pm     Reply with quote
Try changing your HS fuse to INTIO2. That will enable the internal oscillator with regular I/O on pins RA6 & RA7.
Also, setting the TRIS does nothing unless you also specify FAST_IO.
Ronald
SherpaDoug
PostPosted: Wed Aug 27, 2008 8:06 am     Reply with quote
I would note that few programmers need either TRIS or FAST_IO. Just let the compiler take care of things with the default STANDARD_IO unless you see a need to change it.
HTAluvBeBeo
PostPosted: Wed Aug 27, 2008 10:55 am     Reply with quote
INTIO2 is an invalid fuse with 18F2525
My complier version is 4.020
I found the answer:D
the correct fuse probably is INTRC_IO
Is it right?:D
rnielsen
PostPosted: Tue Sep 02, 2008 8:34 am     Reply with quote
Sorry, I simply looked at the spec sheet and it stated INTIO2 as the fuse. After looking at the .h file it states to use INTRC_IO so you're correct. I guess the two don't always use the same wording.
Ronald
