USB CDC issue?
JoeR
USB CDC issue?
PostPosted: Tue Jul 29, 2008 7:46 am     Reply with quote
Anyone else experience this.
I am using the USB CDC library on a PIC18F45550. And it works, usually.
If my pc host app is connected and talking across the USB, no problems.
If the USB is disconnected from the PC, no problem.
IF the USB is connected and the board is running, but the App is not running/exchanging data it will lock in about 2 minutes.
Is there a buffer thats filling...?
Should I catch the usb interrupt?
Thanks,
Joe
abraxas
same thing
PostPosted: Mon Aug 25, 2008 1:43 pm     Reply with quote
got the same problem as you
alex1784
PostPosted: Tue Aug 26, 2008 1:22 pm     Reply with quote
Hi. I am a novice at this, but I recommend you before sending any data to USB module, verify flag of conextion:
 if(usb_cdc_carrier.dte_present){
...//send data
